hey all, just wondering does anyone know of a hills area cruise that mite be coming up soon that will include skylines and other imports? cos i tried organising one on here (just skylines) a while ago when i had my r32. but its gone, i have an s13, but would still like to be involved on this site
edit: hey everyone, meet at norwest tonight, maybe at the maccas or car wash, and maybe a small drive afterwards, don't have much fuel though, but if anyone is interested either post on here or send me a msg on 0410 803 199 cos i might not be on here. Anyone got a suggestion on time?
Edited by NG0387
https://www.sau.com.au/forums/topic/186050-hills-area/
  • Replies 42
The Hornsby crew meet every Thursday and cruise to the Central Coast to meet with the coast-ians. Thats the best regular meet/cruise there is as they are all a fantastic bunch of people!
There isnt anything that I know of specifically in the Hills area organised. Most cruises tend to start in more central locations to attract more people anyway.
https://www.sau.com.au/forums/topic/186050-hills-area/#findComment-3364998
Generally a younger crowd, and a higher ratio of 'street racing kids' to 'responsible car enthusiasts' than some/most car clubs.
It's just a reputation - by no means based on any factual evidence :D
ah cool cool cos i was gonna say i just joined! >_<
i'm young, but i'm an enthusiast! i like my lisence so i dnt want to do anything stupid!
https://www.sau.com.au/forums/topic/186050-hills-area/#findComment-3372415
I'm near Parra. Hills is only 20-25 mins from me. I can meet up with u guys and i know some guys that like cruises too. Some good turbos. Who cares if there's not all Skylines, we're all Nissan owners anyway. I'm a performance enthusiast :)
https://www.sau.com.au/forums/topic/186050-hills-area/#findComment-3375329
sup Galvo.
Yeah im keen on goin on a cruise with sum boys from down in sydney. if you let me know when i mite b able 2 organise sum boys from the bathusrt area to come along
dude!!! finally got ur act together and signed up! yeah for sure i'll try and organise something and give you notice!
https://www.sau.com.au/forums/topic/186050-hills-area/#findComment-3376031
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
