hey pretty simple question, im looking at some Volk GT-P 17x9 +16's and just wondering they will clear the front brakes on a m-spec r32 gts-t? they have a fair bit of dish for the size and offset which leads me to think they dont have a huge amount of clearance behind the spokes to the hub, but they are also have pretty flat spokes so i dunno.
this is the wheel here for anyone interested:
https://www.sau.com.au/forums/topic/186183-will-volk-gt-ps-clear-m-spec-brakes/
surely work wheels would clear gts-t calipers!!!!
they are an awesome wheel, placed at the higher end of the wheel market spectrum -
I couldnt imagine VOLK designing a wheel that woulnd clear gtr calipers, let alone gtst ones
I could be wrong, but
regardless the wheels are hot!!
gl
^^yeh i think u mean low and high disk. problem is it doesnt specify whether they are high or low disk, i mean id assume they would offer the option with the rim its just im looking at buying them 2nd hand from Japan and cant tell what they are.
there's three types of centres for most 3 piece or 2 piece wheels. A, B and C. From memory B centres will clear standard R32 calipers and you'll need C for brembos.
They should be marked on the sticker on the inside, or on the inside of one of the spokes.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
