Any one used this stuff yet?
Hey guys - this pigment comes with instructions and they also have instructions on Paint with Pearls site. We have painted numerous jobs and its good stuff for the price - just buy a GOOD quality clear - mix 1 pkt 1 ltr of clear . Don t forget your base coat and Metal flake if you want it . A GTR would take aboput 4 ltrs of paint once pigmented - so thats a few litres of primer - 2 litres of say silver metalic base coat then about 3 of pigmented clear. In between coates block it back then a final clear coat .
well i was look at the web site for that paint and where are these guys actual located...??
USA -Denvar Colarado - Pigment is cheap - Postage about $25 -here in a week - Mats good to deal with.Pay Pal
  • 4 weeks later...
anyone know of similar sites located in aus??
nope - you could try a local painter - but its bound to be more expensive
heres the apple red flake from paint with pearl mixed in clear Powdercoat - definately need to clear over it and block if used in paint - where as the powdercoat is thicker and more self leveling.
Here are a few pics that my friend took the other night of my to be drag GTR32 straight out of the booth - got lots to do yet. Looks a lttle funny being so
high off the ground as she has no running gear in her - will soon though!
Any way this is about painting your ride - will post up some pics in the natuarl sunlight as it will show the paint with pearl metal flakes better, there is one close up pic but dose not do it justice under fluorescent light. Enjoy.
I don't realy like busy paint jobs but that one looks very effective and not to full on .I admire the painters effort for sure and once finshed I bet it will look a millon dollars on the track
thanks i dont either for streeters- strip -why not i say, looks totally differant in sunlight.
  • 3 weeks later...
Im getting a blue paintjob soon, buying all the paint myself and prepping it then taking it to get sprayed.. Tried to look on the site just a bit unclear, how many packets would i need? about 4-5 since exXu1 said "A GTR would take aboput 4 ltrs of paint once pigmented", But what does it mean pigmented? Im talking from scratch.. Which packet would i get? Im looking for a GTR blue like bayside blue but with that pearl look..
Thanks
Thanks
The pigment is the small packet you buy from paint with Pearls- the pigment goes in your clear- you use clear only. When your pigment goes in the clear it becomes the paint colour you want. You then apply how many coates you want to achieve the look you like.
The pimented clears go over a base coat- say clear with a silver base or metalic even - contact Mat at P w Pearls and he will explain or i am sure ther are instructions on the site.
  • 1 month later...
  • 7 months later...
http://www.paintwithpearl.com/
basically like most pearls, it is a dry flake that is mixed with a base clear. this is then sprayed over the base colour of your choice. just like exXU1 said
the difference in teh styles is explained, but in a basic form, it is a differing of the size of the metallic pieces to change the effect the paint gives. my pics above are the flake, so large pieces are easily identified, where as a shimmer pearl is small pieces so it comes out as a colour change rather than flakey
wow this stuff is awsome, only one problem, there are way too many options!
how do i know what to go with to get the dezired affect?
some of the pictures look nothing like what you would expect from the description!
cheers
Gezza
  • 1 month later...
let me get my head round this, its been a long day
say for example my car is already silver....
I can buy say the blue satin ghost pearl flakes, mix with clear coat, and get my nearest panel shop to spray it and itll look sweet? the silver will have a pearlescent blue tinge in the light?
bout how much would the spray cost at the shop?
you still need to scuff the current paint back, then run the clear and additive, then another plain clear ontop again, then wet sanding and buffing if required.
best to go to your local painter and ask, Darwin prices might be different to other areas.
  • 1 month later...
looking at doing my car in the next month just started prepping it. although have slight prob with wat to do with the sunroof.( bit rusted out thinkin i will just get perspex and silicone it in or something. any opinions welcome. any way thinkin black pearl pigment with the black 00.4 flake sshould look sweet when im done anyone got any pics of cars they have done will post mine when completed.
Hi guys, For anyone wanting to paint they're car's them self. if you want a more in depth look you should consider adding the pearl powder/rainbow flake in binder then clear over the top. Be careful with the flakes too, Cause if you put it in with the clear it will leave the surface of the paint feeling like sand paper. make sure you use the right grade of paper when preping for colour. i recommend 800 grit for pearls and mettalics. and if your paint is in good condition ie not flaking or faded you wont have to prime it.
If you realy are not sure and have limited experience - just search the correct way to apply or send Mat at paint with pearls an email, i am sure he will help, post the info here for all. :D
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
