Hey,
Well, here's the problem I'm having with my R33 GTST at the moment, I had coolant spilling out of the overfill tank for a couple of days, however the coolant levels and running temp of the car was fine, it wasn't overheating at all just normal running temp.
I however, took the car to a radiator specialist and spoke to someone there about it, he said that the radiator cap needed replacing (even though I replaced it about 4-5mts ago). He also said that it wasn't sealing properly.
He also went on to say, best bet is to get a 16 pound radiator cap or replace it with a genuine Nissan one, which I will do tomorrow.
Nissan sell them for $21 and a 16 pound one from Autobarn is $50.
Anyhow, while the car was parked at work today there was a puddle of coolant on the passenger side of the car, it was really weird being dark I couldn't see where it was leaking from so I toped it up drove it home and it was alright.
Though, I'll have to have a look at it tomorrow when there's some more light, just wanted people advice/help on what things I should look out for, thanks.
- Aron
https://www.sau.com.au/forums/topic/186508-coolant-leak/
Stock cap. High pressure radiator caps should NOT be used on a factory plastic radiator.
In the event there is too much pressure, rather than the cap blow, it will shatter your radiator to pieces and cause a mighty mess :whistling:
Factory all the way
https://www.sau.com.au/forums/topic/186508-coolant-leak/#findComment-3371086
Factory all the way
Yeah, I was never planning to buy the 16 pound one, just the genuine Nissan one.
Do you think that could be the only problem though? What else should I check for tomorrow?
Thanks R31Nismoid,
https://www.sau.com.au/forums/topic/186508-coolant-leak/#findComment-3371089
If the overflow isnt leaking, and the radiator cap is new.
You have a crack in the radiator somewhere i would imagine, or turbo line possibly as you said passenger side.
Maybe a leaky plug somewhere around a water gallery.
Things like that can be hard to find as the water runs along parts, so it could be coming from the other side of the car, best to trace the leak if the cap doesnt fix it.
The radiator cap lip is plastic isnt it? So it cant be that.
https://www.sau.com.au/forums/topic/186508-coolant-leak/#findComment-3371106
Here's the update..
I went and picked up a genuine Nissan cap this morning and put it on, started the car and noticed that there is coolant dripping from underneath the car, around the area of the oil sump and fan belts, can't seem to pin point where it is coming from though, any ideas?
https://www.sau.com.au/forums/topic/186508-coolant-leak/#findComment-3371352
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
