Thanks again for info.
I had the (nasty, as it turns out) wheel bearings pulled this week, and a new set pressed in yesterday. Im going to reattach the rear trailing arms ASAP, and then reassess the situation. If things STILL aren't running smoothly the valves are next on the job list.
  • Replies 63
Ok... I took the car to the NSDOC show and shine and it actually made it there in one piece! It got a good run later that day and went well, but I still think the car is falling short of its full potential.
At the moment the grinding from the rear has gone; clearly the wheel bearings were absolutely cactus, and brake pedal pressure is good. I am yet to try experimenting with different proportioning valves, but if things go well over the next while I may not need to.
The engine is also going much better than previously, but the power still seems to drop off a little too early, around 5,500 rpm - pushing on to 6,000 rpm and above just seems to upset the old girl. I am acutely aware of this because on the few good runs that I have had over the last year she would scream up to 7,000 with no signs of resistance. Something just isn't quite right.
Next up I'm going to move the electric fuel pump to the rear and insulate the fuel lines with heat-resistant wrap to see if that makes any difference.
(many thanks go to Blind Elk for the tips and the chat on the weekend).
Was that you getting around in the Nissan Shirt?
Ill try and get some pic's up soon
Yep, black T-shirt with a Datsun logo. I was looking out for your 240k's. Did you come with a different car?
Ill post up some pics this evening under the NDSOC post.
He was driving one of my R31's, the fire brigade one.
Hi, I'm sure I know who you guys are now, sorry I didn't introduce myself on the day.
Your R31's were lovely by the way!
You know who we are now, so next time come up and slap us on the back like we're old mates lol.
I did like your car BTW. Carbies, and several of them is always very cool.
I love my 31's thanks for the compliment.
we did have a good chat, i told you about the other car @ center rd, lol, im k's are off the road at the moment :D but soon i hope ill have one up and running
we did have a good chat, i told you about the other car @ center rd, lol, im k's are off the road at the moment :O but soon i hope ill have one up and running
Ahhh! (Slaps forehead) it all comes clear now. Im going to have a look at centre rd probably this week. Good luck with the K's by the way.
there was one in the back of an old warehouse, had flames across the bonnet etc... it was on ebay a year or so ago...
it looks like drew may have bought it as spares??? i dunno
but i have heard they creak and sag a whole lot as the supports are gone from the roof etc.
yeah would be pretty weak, but would be nice to see one.
have seen a couple pics of an R31 Convertable, only 2 were ever made... well by Nissan anyway.
Hi,
Yeah, a mate picked it up to use as spares. It looks ok from a distance, but when you get up close its just a 4 door with the roof crudely cut of and the rear doors welded up! A guy was using it to belt around on his farm!
Good news: I located the source of the grinding noise from the rear. One of the calipers had a lot of play in it. By reefing on the handbrake cable you could see if flopping around. An easy fix!
Bad news: I relocated my fuel pump to the rear, but the car still cant be pushed past 5,000 rpm. Grrrr... I got more out of my L24 running a single carby! Looks like I'll have to see a specialist. Some of the guys and the NSDOC show and shine were squeezing out triple the horsepower that I make from their L series engines.
I haven't forgotten about the mr30 "coupe", Ill get some pics etc up tomorrow.
D
Errr... Took the car to Nissco to try and find out what is draining the power so badly. The consensus is... wait for it... Carbies! That's right, the $1500 rebuild that I am bitching about in the title of this thread is the culprit. The needle and jet setup is wrong, causing the car to run way lean. About 18-20 to 1 air fuel mixture, as opposed to the ideal 13.5 to 1. So now I have to go back to the carby specialist, to ask him politely to sort it out... or Ill be forced to throw a stick on his roof.
I fixed the crappy caliper though.
Interestingly, the rest of the car came back with a fairly clean bill of health.
Anyway here are some pics of the mr30. Mags, you are welcome to come and get the spoiler (which is fairly convincingly attached to the boot) and the glass if you still are interested.
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
