  • Replies 705
Posted Images
Also watching intensely... that will give me a few months to get the GTR up to pace.
Will a CAMs L2S licence be sufficient? Or even needed? I'm debating whether to renew mine.
Yeah L2S license will be the requirement.
What i found em :-)
They were all homeless and stuff so i give em a good home.
LOL might even bolt a set onto the porsche and take her for a run....just as soon as the clouds disapear that is.
and there is this old shit heap needing a set too
well the r34 is here!! so stripping it down wont be too far away!
if anyone knows some one that needs some r34 bits let me know! apparently it has a tv tuner for the MFD, a good stereo with amp in the boot, all the brakes will go, seats, etc etc will put em up in the forsale section,
but the engine and gearbox i want to try and sell while it's still in the car before we strip it, so whoever buys it knows the state of it!
BTW the r34 i was originally getting from japan , has never eventuated(long story) so this one has been locally sourcedit will be a shame to strip out a fully complied registered r34!!! :P oh well you get that.
pics to come over the weekend hopefully.
another one bites the dust - at least its to one of the best causes possible!
the spec's for the car so far rare, (it will be purely timeattack & sprints, with a sports sedan lod book)
hope to have it done by may! (i hope)
(nearly all this stuff i already have waiting for it)
engine 3 ltr
lovely head work! :P larger valves & inserts etc
hi lift cams around the 280 mark
dry sump
hypertune manifold
not sure turbo setup yet but external gates
electronics
autronic ecu
cdi ignition
motec dash
tranny 6 speed sequential holinger
carbon shaft
cusco diffs
suspension ohlins
full ikeya formula arms
stub axle mods
brakes
pedal box
bias adjuster
alcon monobloc v8 supercar brakes front and rear 365/345
fully caged and seam welded body
single seat
carbon doors
lexan glass
carbon boot
carbon bonnet
aero front bar, side skirts and wing (not yet sourced)
hopefully carbon dash
custome made wheels
custom radiator oil cooler system
thats it for now!
hope it all comes off! but will be posting pics with progress.
You know what the scary thing is though? The 32 would most likely scare the pants off a majority of performance car drivers. You're just getting used to the next level of 'scary'... where does it end? :thumbsup:
On second thought... Ignore what I just said, continue building the super fast scary R34! I want to see this monster! :P
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
