Ok, the 18's have arrived and the 17's have come off. Time to sell :P
Rims: AVS Model 5's
Size: 17 x 8 front, 17 x 9 (+30 offset) - will double check offset on the front.
Tyres: Advan Neova's 255/40 rear - Bridgestone RE030 235/45 front
I took off the front Neova's because they were chopped out on the inside. Don't think would be road-worthy, but am happy to throw them in for free as some muck about tyres for drift days/skid pans etc :blush:
So it's a set of AVS Model 5's with tyres, plus 2 extra Advan Neova's (235/45/R17)
Price: $1600
PRICE DROP! $1350
getting silly now!!!
$1150!!
Here are some pics, i'll have to take some better ones soon. After i given them a clay/polish and some wax as well :cool:
pic of my car at car yard in Japan in 2004, when J-Spec found my car for me....aaah the memories :woot:
and just for bling :D
these are prob 19's by the looks of it
Seems like approx ~$150 is the going price for sending rims interstate, judging from other rims threads.
These are top quality Jap rims, and for reference when these are new....
http://bt-revolution.com/AVS%205.htm
$2799 for a set. JUST rims
http://www.yokohamatire.jp/yrc/japan/wheel...del5/index.html
Advan Neova's are about $350-$400 a corner. NOT cheap tyres.
If you're after a QUALITY set of Jap rims, let yourself be known :)
cheers,
daniel
https://www.sau.com.au/forums/topic/187385-fs-17-avs-model-5s-wtyres/
been asked about some more pics. These show tread left and the marks on the rims...
The pics of the tyres themselves are of the Potenza RE030's that are going to go on the fronts. The other tyre pics are the rear 255/40 Neovas
PRICE DROP: $1350
some more piccies
^ that's why the front tyres are coming off and the Potenza's going on. These are being thrown in for FREE (not roadworthy)
so you just want the rear rims and that's it?
sorry mate, looking to sell as a whole set. Whether people take the free Neova's if up to them, but the rims and tyres are going together :D
  • 1 month later...
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
