Hi all.
I have an R33 12/92 RB25DE and was wondering if anyone has had to changing the timing belt and tensioner where did they get it from and what was the part number? I want to make sure I get the correct one.
Are there any tricks to changing this belt, I heard it possible has a variable valve something a-rather..
Thanks
https://www.sau.com.au/forums/topic/187390-timing-belts/
i got my timing belt and tensioner kit from CBC. my mechanic did it for me, and i would probably recomend u do the same cause it takes quite a while.
the kit cost me $375. the timing belts are the same for r33 and r34.
your lucky i still have the box!! part number: N2600T HP
https://www.sau.com.au/forums/topic/187390-timing-belts/#findComment-3382267
i have a tomei belt. RB20DE(T), RB25DE(T), RB26DETT are all the same. only exception is RB30.
can pick them up anywhere, search on nengun, perfect run, greenline.
it's possible to do it yourself, but it's a mega mish to take all the other belts off. you will also need a timing light to re-check your timing. while all the other belts are off you should also change the water pump.
https://www.sau.com.au/forums/topic/187390-timing-belts/#findComment-3382306
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
