OK all i just paid so ill see you all there.With the new found power i have received im sure to turn a wheel or two.
Goodbye SAVAs you pieces of garbage.Will definatley be honing my drifting again as ive been out of the driving day loop for a couple of months due to my upgrades.Also have a Project Mu brake kit on the way so hopefully will be installed by the 27th.Fingers crossed.
My last effort.Those wet patches really stuffed my run.
hi dave.have we met or seen each other before.i am from ingleburn.i drive a white r33 with bodykit and white rims.
you have an impressive list of mods.if you really want to get better at drifting its allot easier with a decent lsd.
if you want to do a diy $20 lsd rebuild jobbie then go to the link in my sig.mine is still going good.youll have to specify that you want the shims asap though when you order them in.
the rear end is allot easier to predict/hold sideways.
this saturday!?!?!?!!?!
awesome Steve!!
Congrats mate, Im sure the day will go freakin awesome for you and your mrs!!
*beersforall!*
Oh, and re:semi's - at the texi - I was on the wet skid pan and I got the worst times with my semis, understeered everywhere and at one stage I almost came off the track cause of them!! Ando (a31deviat) wasntthebest either!!
On the back track though we were pretty quick!
Craig - mate, Im gonna take you up on the diff shimming - when I get time!! :thumbsup:
There a couple of white 33s in the area i would have driven past you at some stage probably.The biggest pain at the moment is the Hicas and i need some solid bushes for the rear as it tends to axle hop alot.
Cant wait for the day though! All time attack with the slalom and trying to keep the back end cranked sideways in the cloverleaf.But then again could be all time attack,would like to better my 3rd place from last time.
well im gonna have a go this time as well....as i havent sold my 33 yet i have a decision to make....the gtr or the gtst....ill get my brother to take one so I can swap and change on the day....
Craig - mate, Im gonna take you up on the diff shimming - when I get time!! :P
all good.like we discussed.note:may inccur small sexual favours and beers :)
Hey jeff...see you there man..this time..pls...don't F*** up..hehehe
Eug.
it was pretty close but the guy in the BMW was to hard to beat on the dry skid pan.he was good.
but for the rest of us meer mortals it was really close for the top 6 in the rwd category.there was less than a sec separating us all.jeff was going well untill the spinout.
if you want good times then sliding the ass end out all of the time isnt an option.as you know.
all good.i will come down,even if i am not competing,on the day most likely and watch.
crap. i dont know if i will have my car for the 27th.
i will have to get back to you on it, but will definitely come watch. Or maybe i will take the cressida out lol we shall see. i havent missed one yet.
eug- what fu*& up :rolleyes:
actually i had a few last time lol. im fixing my reaar camber now so maybe i wont just wheelspin everywhere. then we will see.
Just got an email from Autosports admin.Telling me the Ultimate control day has been cancelled!!!
They are giving refunds to the people who have paid already.
Im spewing i had the car prepped and everything for it.
>_<
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
