hey everyone :blink:
spoken to a few people about installing a custom inlet plenum (thanks to bullet32 for the manifold! :blink:) on an rb20 with a stock ecu.
half the folks said, "it will lean out your rear cylinder. make sure you've got an aftermarket computer" the other half, "shouldn't make a difference. air pressure is air pressure"
if i did have an engine management system that allowed to tune individual cylinders, it'd want to be a pretty nuts engine then yes?
and isn't air pressure always going to be air pressure?
cheers.
https://www.sau.com.au/forums/topic/187495-custom-inlet-plenum/
some different manifold's will cause the rear cyclinders to lean out not good if you are going to case big power levels if you are after some companies that make flow tested manifolds i would suggest plazmaman.com or hypertune.net. just for a start.
plazmaman only really does inlet plenums
Edited by neofenrir34
to sort the leaning out problem, get the injectors flow tested
put the largest flowing injector in the 6th cylinder, second largest in the 5th etc all the way to the lowest flowing injector in the 1st cylinder :rolleyes:
should fix the leaning out issue
You wont have a problem if you get a Power FC, Microtech, Haltech etc. because these will allow you (or your tuner) to rich up or lean out your mixtures and get it running right.
That plenum came off a Gtst that was making over 300kw at the wheels and the engine was about 300,000km's old when he decided to take the plenum off, so I think you'll be fine.
Is changing the plenum a worthwhile modification? Or something to only really consider when most other options have been done?
And is the primary purpose for changing the plenum for better/quicker throttle response?
turns out the plenum didn't fit anyway hahaha BUT danny (performance garage) is taking the throttle body off it and attaching it to my original plenum, essentially the same thing but to fit my RB20 :P
i will eventually get an aftermarket ecu (thinking GReddy Emanage or Haltech. Anyone had experience with one of them?) spoke with danny and it should be fine till then. not going to be driven much in the meantime anyway.
depends. if you're looking at mods that are value for money there's no point as there are other modifications that will give you more power. yes you'll get more torque :O i'm just setting the base down as i have plans for the engine later. plus i HATE the stock RB20 inlet plenum setup (**waits for fans to start lighting torches and grabing pitchforks** ;) )
haha don't sweat it :P actually ended up saving money. the custom pipes i would've needed to suit the stock plenum would have cost about $200-$300. this new custom plenum will be about another $100 :) maybe $200
is there a difference in the throttle bodies? haha didn't even notice
cheers.
Air flow... it's all about how much air you can move and how fast you can move it. the more bends and twists and changes in pipe size will make a difference.
  • 1 month later...
air pressure is one thing and air flow is another.
although air pressure can be constant between cylidners the air flow is not. it is affected by a large number of factors, but as mentioned before, the less bends the better. aerodynamicswithin the plenum play a major factor and not something that can be shown on a flow bench, but more on autocad style programs which simulate different circumstances of air flow/pressure. all this and then throw in air speed and plenum volumes and the fun begins......
more pressure = more airflow (in general*)
more air flow = more power (with the right amount of fuel of course)
then again you can have
more airflow @ less pressure (due to less restriction) = more power...and this is what a correctly designed and fabricated plenum should provide.
* more pressure can sometimes produce the same amount of air flow at a lesser pressure since an orifice can only flow a certain amount of air regardless of pressure. basically, at some point the air "banks up" and can not get thru
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
