stock R33 rims with tyres firm $200
set of 17 impul rims 17x8 17x9 rims only 5x100 $300
set or 17 rims black centre polished chrome lip staggered dish
deep dish rear 5x114.3 suit skyline $600 ono
genuine GTR R32 struts with performance HKS SPRINGS $250 the lot
R32 half cut minuse the motor shell only ,comes with dash , 2 struts , 2 hubs (5 stud)
$350 the lot
s15 bonnet genuine nissan $500 firm
please sms me or ring on 0416515558 or after hours 34022927
my computer is in shop getting repaired so i wont have internet access for a while
but i do my best to check for pm
https://www.sau.com.au/forums/topic/187650-rims-n-struts-half-cut/
bump
the impul rims r 17x8 17x9 two piece alloy rims 5x100
the other set r 17x8 17x9 5x114.3 skyline off set front tyres r 235/45r17 rear tyres r 255/40r17
chrome lip dish front have at least 2in dish back have at least 4in dish black centre mags
r33 stock rims sold
black 17 rims sold
every thing still 4 sale
impul rims 17x8 17x9 offset 31front 38 rear
sms me on 0416515558 and i will send u pics to your fone by pxt
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
