What Would You Choose
28 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey there guys, im new to the whole skyline thing and about to purchase one... problem is, what one?
Im either going to go a R32 Gtst or a R33 Series 2 Gtst
Would would people suggest?
I know i can buy a R32 cheaper and spend the money on it... or just buy a newer car with some mild mods
or pro's and cons of either one...
Any help would be most appreciated, Thanks guys
-Griffo-
Edited by Griffo04
https://www.sau.com.au/forums/topic/187676-new-guy/
im sure this topic will be pretty biased.. but here goes:
i would choose the 33 s2 simply because its newer, more powerful, bigger turbo, may have less km's, mild mods will see it with some pretty good numbers...ect ect..
realistically, you need to choose what you like, some people absolutly hate the look of 33's, while others hate 32s. regardless of that, the way i look at it, the newer more modernised updated version is ussually the winner.
of course people will argue against it, so the best influence and decision is your own.
also list some specs about both cars. i.e what year, current mods, future mods, kms, ect.. that will then make better opinions than just whats better a 32 or 33.
good luck and welcome! :bunny:
https://www.sau.com.au/forums/topic/187676-new-guy/#findComment-3386591
i got a series 2 r33. IMO - it looks bloody nice (specially the back), more power, more space inside, nicer interior etc. And as mentioned - minor mods can make a huge power difference to the stock version. However, the car is big (compared to the r32) - both bulky and its as long as a family sedan.
R32, is old - so there might be more problems than the r33 - but this comes down to how the previous owner used it. If it straight from japan, you probably would never know how the previous owner used it (i.e if ur buying one off a SAU member, u will have an idea as to what the car has been through).
Both are great cars on the road and track....pretty much, either one u go for, u cant lose - unless u buy a lemon.
https://www.sau.com.au/forums/topic/187676-new-guy/#findComment-3387204
both are old, heck even R34's are getting long in the tooth,
Depends how the particular car you're looking at is kept
Personally I'd go the Series II R33, with the front lip they can look quite mean
Good luck with your purchase
https://www.sau.com.au/forums/topic/187676-new-guy/#findComment-3388151
Thanks for the advice guys, looks like the 33 S2 is the members choice, but still i guess it does come down to my own decision, i do love the style and look of a 32 but the 33 being newer and a better chance of having less problems is prolly going to be my choice.
All i have to do is find a decent one in brisbane that isnt over priced....
https://www.sau.com.au/forums/topic/187676-new-guy/#findComment-3388597
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
