What Would You Choose
28 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey there guys, im new to the whole skyline thing and about to purchase one... problem is, what one?
Im either going to go a R32 Gtst or a R33 Series 2 Gtst
Would would people suggest?
I know i can buy a R32 cheaper and spend the money on it... or just buy a newer car with some mild mods
or pro's and cons of either one...
Any help would be most appreciated, Thanks guys
-Griffo-
Edited by Griffo04
https://www.sau.com.au/forums/topic/187676-new-guy/
im sure this topic will be pretty biased.. but here goes:
i would choose the 33 s2 simply because its newer, more powerful, bigger turbo, may have less km's, mild mods will see it with some pretty good numbers...ect ect..
realistically, you need to choose what you like, some people absolutly hate the look of 33's, while others hate 32s. regardless of that, the way i look at it, the newer more modernised updated version is ussually the winner.
of course people will argue against it, so the best influence and decision is your own.
also list some specs about both cars. i.e what year, current mods, future mods, kms, ect.. that will then make better opinions than just whats better a 32 or 33.
good luck and welcome! :bunny:
https://www.sau.com.au/forums/topic/187676-new-guy/#findComment-3386591
i got a series 2 r33. IMO - it looks bloody nice (specially the back), more power, more space inside, nicer interior etc. And as mentioned - minor mods can make a huge power difference to the stock version. However, the car is big (compared to the r32) - both bulky and its as long as a family sedan.
R32, is old - so there might be more problems than the r33 - but this comes down to how the previous owner used it. If it straight from japan, you probably would never know how the previous owner used it (i.e if ur buying one off a SAU member, u will have an idea as to what the car has been through).
Both are great cars on the road and track....pretty much, either one u go for, u cant lose - unless u buy a lemon.
https://www.sau.com.au/forums/topic/187676-new-guy/#findComment-3387204
both are old, heck even R34's are getting long in the tooth,
Depends how the particular car you're looking at is kept
Personally I'd go the Series II R33, with the front lip they can look quite mean
Good luck with your purchase
https://www.sau.com.au/forums/topic/187676-new-guy/#findComment-3388151
Thanks for the advice guys, looks like the 33 S2 is the members choice, but still i guess it does come down to my own decision, i do love the style and look of a 32 but the 33 being newer and a better chance of having less problems is prolly going to be my choice.
All i have to do is find a decent one in brisbane that isnt over priced....
https://www.sau.com.au/forums/topic/187676-new-guy/#findComment-3388597
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
