Looks pretty good, though i think that you
would need too heat wrap it well!
Seems kinda expensive too
Kinda expensive? A good manifold well made is 1k+
Anyhow, what is the setup?
Stock or near stock turbo, not really worth it and money can be better spent elsewhere ;)
That runner is shorter than the rest
But its better than some of the other dodgey ebay ones I have seen.
Does anyone know what grade of stainless is used? 2mm or 3mm?
It doesn't look shorter to me.
How can you be sure?
I've built complex manifolds before and even with a tape measure you can only estimate effective length.
For 100% accuracy I measure volume with liquid.
haev a look at the pic - The three on the right are full length, the one on the left that I have marked falls short of the collector and is plumbed in with runners 2 and 3.
Its pretty obvious.
Either that or the designer has made th pipe slightly bigger after where runner 1 plumbs in to accomodate. Maybe that is the case. But its not tuned length then.
if that manifold has the pipes merging b4 the collector (looks like it in the pic), then it kinda defeats the purpose of being tuned length. would be better than a standard manifold, but id still rather have 1 where all six merge together at the collector. imo thats the best design for good response
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
