I've found a GTR V-Spec only done 4000km and can get on the raod for $92k including road side assist and 3yr warranty etc etc. Going by what I've seen on the second hand market looks like a great buy.
I'd apreciate any opinions from anyone as I've only been looking around for a few weeks now.
Thanks in advance
edit: - '99 Model :)
https://www.sau.com.au/forums/topic/18779-r34-gtr-v-spec-good-price/
Guest RedLineGTR
i'd really get a pro to check the "4000km" since it would seem to be fake unless it has an aftermarket dash or the car was just used for "track" use...but 4000km is really low. It is a decnt price. But get it checked out by someone who knows what he/she is doing, also check the overall condition of the car, like the condition off the enigne bay. Have you test driven it?? Make sure no unsuall noises occur while your driving and listen to the engine while it's at idle etc etc...Also you could get a friend who may have one to go for i ride while test drive, check the lcd display for any errors or the engine getting to hot etc. Hope it helps i'm sure alot of people can add more.
Thanks for the info guys.
Apparently it's an ex demonstrator from Japan. Been here about 6 months. I am a little suspect, as 4k for 4 years would be extreamly rare. The engine bay looked almost spotless. I think it may have been used for some "advertising" for the dealer at certain track meets or something and there are a few superficial marks on the body, maybe from shipping alone. Everything is totally stock so posibly joy rides for interested buyers of later models ie '00 & '01? Haven't driven it or really checked it out yet, obviously I will before buying tho....
Is there anyone in Melbourne that could be recomended to do a check? Willing to pay for services of course...
he he yeah - MR2 has been with me for a few years now. Had it bought in personally in mid 99, so time for an upgrade. I'm earning a little more now than what I was 4 years ago :-)
Mick - Do you have contact details for Ben? Can't find a white pages listing for Race Pace
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
