Hi there.
Got the Fc datalogit, laptop, LM1 hooked up to fc datalogit, and a apexi power FC.
Now I need to know how the Af should be..
Could someone rougfly point out what AF ratio I should aim for, layed out on the 20 x 20 inj map. Not each map point, just say the first 5 x 5 should be around XX, then up to 10 x 10 it should be around XX..
Thanks.
Best Regards
Ronni
https://www.sau.com.au/forums/topic/187834-newbie-help-to-map-apexi-fc/
the first 10 rows should be aiming at about 14.8:1
After that, I'd start richening up the mixture row by row until you can get the last line the car uses to run about 12:1.
I'll get a picture and show you in a sec
it all depends on the engine and setup that your running.
some cars need to run a little richer to run correctly on lower load points.
I find that some cars can run fine at 14.7 on cruise across the whole board but some cars will run like a dog and will need to be richen'ed up to around 13.6...
For AFR on boost it also depends on how modified the car is. If you have a stockish car then 12 afr is fine... if your pushing alot of power then its good to run it in the low 11's to keep the engine cool.
I disagree with that statement.
I'd still run a flat 12:1, as any lower starts to rob you of power an is just rumming the engine too rich. If the car is overheating, then there is something wrong with the Coolant system.
I'm running 13:1 afrs with water methanol injection. Engine sits at about 79 degrees after a few hard runs.
I'd only go richer if its pinging and taking timing out doesn't stop it in that area, but I have never come across this so I don't you should either.
this is what I run without WMI as promised:
Why do people allways run their cars on the edge to get max power at the expense of reliablility ?
Running a engine hard on .85's can work yes. But what if there is a bad batch of fuel in the question ? or a fuel pump starts to fail a little or a fuel reg does something silly it could change the afrs to .87 .88's on a highly tuned engine after a short time you will have a broken engine.
I like to see mine running at .80's and .82's when im pushin 25psi and 360rkw.. sure i could bag a extra 20kw if i leaned it off but i ike my engine and i want it to last.
More power is not allways better.. reliability is where its at as far as i am concerned
If you have a really good quality fuel system and EGT's in each cyl to make sure every cyl is getting the exact amount of air and fuel as each other and you are 100% sure everything is working correctly then sure run it lean...
Using water changes everything and you can run it leaner.
Edited by Guilt-Toy
well, of course your going to run that kind of richness at that power and boost, but that kind of boost is probably too high? Have you considered looking at a turbo that provided more flow? Or maybe some cams?
Remember, boost is bad, its a measure on how much the engine is resisting the air your trying to push into it.
But if your talking 11.2:1 afrs, I still thats simply too low for even your setup. I'd look at 11.5 - 11.8. All you need to do is watch the knock, and I bet if tuned properly, there wouldn't be any at all any way.
Its not the fuel (to an extent) you should be focussing on when you want the engine to last, its timing. Pull the timing out if you think its going to ping \ blow up \ be running on edge.
Edited by The Mafia
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
