  • Replies 50
nope, just time consuming. take off the crossover pipe and associated pipes. take off coil cover. undo phillips head screws just under cam covers. then do the sam for the ones inside, just near the coils. then lift off, carefully not to ruin the rubber gasket.
now ur cams and stuff will be exposed, so close the engine bay ok. lol.
than sand and buff to your hearts content :(
probably takes 1hr for a newbie to do it.
than sand and buff to your hearts content ;)
ahh one hr would be no hassel, so is it worth replacing the gasket while the covers are off? How many screws in total (not including the coil covers ones obviously?) recommend putting a sheet or something over the engine??
Hame
yea mate, when u get off all the hoses, and the cam covers off yea, probably 1hr. from memory i think there is roughly 5-per side. and 4 sides, total probably 10-15+ screws. the gasket is rubber, and it is constantly lubricated with oil, so unless the engine is fkd, it should be in top condition, be careful, if it has never been replaced, it will most likely be stuck in the lid of the cam cover=dont lose it. just yer, make sure u close your bonnet, i had some hair getting in there from my dog. dont botha with a sheet, keep the bonnet closed. :P
I replaced the rocker cover seals in mine when i did the major service. Mine was leaking tho. When i pulled the old rubber seal out it did feel a bit hardened. But new seal kit was quite cheap so i just placed it. The kit i got came with rocker seals, moon seals, and all new rubber grommets for the screws that hold the cover on.
I would prob put a cover over the cams while you have the covers off. Also watch that those stupid gromments that go under the screws dont fall off the rocker cover and end up in the engine. I started getting worried when i counted the grommets and came up one short. Thought that it might have dropped into the engine or something. When i was cleaning up i found it under the car. Must have fell through the engine bay onto the ground. Lucky for me. I didn't really want to fish it out of the engine.
G luck
well i going to give it a crack today!! so yeah i will watcgh out 4 that..interested in replacing the seals/gaskets, u get them from nissan?? how much?? n u have 2 use glue?
  • 3 weeks later...
Hey Guys. Just started doing my cross over pipe today (using a sanding wheel on a dremmel). planning to get it all to a pre polish stage until i get a work vehicle next year. Then buff it all up at the same time. Plans are to polish cross over pipe, rocket covers, Plenum, Turbo heat shield, brackets in that area. All the rest of the bay planning to paint or put covers over.
Quick question. What is the easiest/quickest way of getting around the nipples / grooves / gaps in all the different bits?? Are people finding it easiest by hand on the tight bits? or would there be a tool/ dremmel attachment that would be quicker and more effective????
Luke...
Luke...
I'm looking for the same answer as well. It is really really hard and sometimes impossible to hand sand the little grooves and indents and crevasses. The dremel tool attachments sometimes don't work that well either. Any input appreciated of course!
Great job. is it possible to polish the rocker covers if they are still on the engine
Ive done mine (well. got it all prepped for final polish) without taking the covers off apart. I just took taken off the coilpack cover, and all hoses/pipes etc that are in the road. then used wet sandpaper carefully to avoid any dust and stuff forming which could float off into unwanted places . After i had sanded back a section i wiped it clean. It came up pretty good. No photos just yet though won't have any till the local Australia day show and shine. But yeah. Doing it without pulling off is possible. Just be wary of rubbish that you polish off getting into nooks and crannys
Luke...
HmM i had alot of troubles when it came to sanding around groves etc. Just did it by hand btu took me ages. I guesss you could work on the covers while they are on the engine but it might be a bit harder on your back leaning over the car for hrs. A dremel or similar took might make the job alot faster tho.
  • 1 month later...
u think maybe the rocker covers will eventually start to create surface rust from the scratched surface?
anyone found out first hand?
also are the moon gasket (rear camshaft gaskets a necessitity for when you also replace the rover cover gaskets?
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
