Would it be normal if the car DID stall?
The mixture will go super-lean, so there's a fair bet it could stall.
I wasn't aware that there was any form of Gating in the air inlet to the PCV system.
The hose from the passenger-side rocker cover connects with the inlet pipe between the AFM and the turbo compressor.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
