To replace a GT2530 with a GT2860RS centre section (cartridge) you will need to re use the GT2530's turbine housing .
Garrett don't make a T3 flanged GT28 turbine housing which you will need on a single turbo RB25DET exhaust manifold . The GT2530 (RB25 spec) turbine housing should go straight on a GT2860RS cartrige because they both use the same turbine .
As for the tune I guess you could try it innitially with a little less boost to see if it wants to ping or run lean on full load .
Cheers A .
