Hey,
Ive noticed recently that when i reach 100km/h i get a huge vibration feeling throughout the car.
Cant even see through the rear view mirror as its vibrating.
Vibration can be felt through seat, gearstick etc basically the whole car.
This started to happen after a new clutch install...
Is there any chance this could be caused from the installation?
Thanks
https://www.sau.com.au/forums/topic/188319-vibration-at-100kmh/
  • Replies 51
was the flywheel machined properly? wat sort of clutch was installed? was the tailshaft done up properly? is the crossmember rubber mount done up properly? the 2 little bolts in the middle of the crossmember get forgotten about alot
flywheel was machined by workshop
exedy heavy duty clutch with 1050kg pressure plate
Not sure about all the other questions as workshop/mechanic did the swap.
Will be going tomorrow to have a talk.
Just wanted some info from SAU before i head over there :P
Took it to a wheel/tyre specialist, they took car for a test drive and said it wasnt wheel balance/alignment related.
Taking car back to mechanic on Friday to see if he can fix the problem, mentioned to him that it could be tailshaft and he said it could be a possibility.
thanks turboedsloth
Yeh, i suddenly had a haggard vibration through the tailshaft of my old gts-t once at a pretty high speed, arrived at home and had a look under the car, 1 of the bolts from the bracket that bolts the tailshaft to the undercarriage had fallen out and it was hanging on a 20 degree angle, luckily no damage, evil thing
Just got back from mechanic which double checked the tailshaft.
Everything is tight and put back the correct way (tailshaft was marked upon removal etc)
Ill book in for a 4wheel balance regardless of what the test driver said, that way i will be 1000000% sure it isnt a balance problem hehe
  • 1 month later...
I am having the same problem with my GTR. Judging by the fact that you have a GTS-T, helps me rule out anything to do with the 4WD system.
I can tell you it isn't a wheel balance because I just had new tyres put on a week ago accompanied by a full electronic wheel balance. Everything showed 100%.
I have been told it could be the diff and so far, I am believing it. If you find out before I do what the problem is, could you please let us know?
I'm in Melbourne too and wouldn't mind meeting up to know for sure if you're problem is the exact same as mine. Sounds like it though.
Fulvio.
PM sent, mechanic also mentioned that if a wheel balance doesnt fix the issue, then it could be the diff.
Getting camber/castor/steering rack/pineapple bushes changed as we speak along with remove/replace of a leaking power steering rack.
I will let you know if i still have a vibration problem afterwards
hrmm
well all my suspension bushes have been replaced and a 4wheel balance & wheel alignment were done yesterday.
Vibration is still there at 100km/h
Went back to the suspension place to double check everything, and he mentioned that if the vibration is felt through the back seat, floor etc then it is a driveline vibration.
Also mentioned that it is the tailshaft as in the r32 its in 2 parts or something and happened after clutch install.
hey guys! i just had a similar prob, i had a gearbox replaced and the car had vibration
at over 80kph, it ended being the centre bearing was shit and the tailshaft needed to be 15mm longer. but the damage also went to the yoke seal on the gearbox.
best thing to do is take it to a driveline specialist. not including the price of the box,
that monkey mechanic who didn't check his work has cost me $1200.
could have bought a rb25det box after all,, :D
excuse my stupidity but where is the centre bearing you speak of?
i have the same exact problem aswell, approx 105km/h and it shakes, only gets worse and you go faster too
have a feeling its the diff or gearbox as it makes a grinding noise between 2-2.5k on each gear aswell AND also can hear a bearing spinning noise (input shaft bearing?) when the clutch is not pressed and its sitting in neutral
tek 01, the centre bearing sits roughly half was between the gear box and the diff... best way to check if it's buggered or not is to through yourself under the car...may need to be jacked up at the rear and push and pull on you tail shaft, if it moves around and clunks it's stuffed... if it stays relativly 'center' it's not you centre bearing... we have a distributer in makcay called hardy n spice.... thats where i got mine from...they seem to know there stuff
sounds alot like your thrust bearing...is it absolutly every gear that it grinds at 2-2.5 k?........ how many K's on the car?
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
