Hey,
Ive noticed recently that when i reach 100km/h i get a huge vibration feeling throughout the car.
Cant even see through the rear view mirror as its vibrating.
Vibration can be felt through seat, gearstick etc basically the whole car.
This started to happen after a new clutch install...
Is there any chance this could be caused from the installation?
Thanks
https://www.sau.com.au/forums/topic/188319-vibration-at-100kmh/
  • Replies 51
was the flywheel machined properly? wat sort of clutch was installed? was the tailshaft done up properly? is the crossmember rubber mount done up properly? the 2 little bolts in the middle of the crossmember get forgotten about alot
flywheel was machined by workshop
exedy heavy duty clutch with 1050kg pressure plate
Not sure about all the other questions as workshop/mechanic did the swap.
Will be going tomorrow to have a talk.
Just wanted some info from SAU before i head over there :P
Took it to a wheel/tyre specialist, they took car for a test drive and said it wasnt wheel balance/alignment related.
Taking car back to mechanic on Friday to see if he can fix the problem, mentioned to him that it could be tailshaft and he said it could be a possibility.
thanks turboedsloth
Yeh, i suddenly had a haggard vibration through the tailshaft of my old gts-t once at a pretty high speed, arrived at home and had a look under the car, 1 of the bolts from the bracket that bolts the tailshaft to the undercarriage had fallen out and it was hanging on a 20 degree angle, luckily no damage, evil thing
Just got back from mechanic which double checked the tailshaft.
Everything is tight and put back the correct way (tailshaft was marked upon removal etc)
Ill book in for a 4wheel balance regardless of what the test driver said, that way i will be 1000000% sure it isnt a balance problem hehe
  • 1 month later...
I am having the same problem with my GTR. Judging by the fact that you have a GTS-T, helps me rule out anything to do with the 4WD system.
I can tell you it isn't a wheel balance because I just had new tyres put on a week ago accompanied by a full electronic wheel balance. Everything showed 100%.
I have been told it could be the diff and so far, I am believing it. If you find out before I do what the problem is, could you please let us know?
I'm in Melbourne too and wouldn't mind meeting up to know for sure if you're problem is the exact same as mine. Sounds like it though.
Fulvio.
PM sent, mechanic also mentioned that if a wheel balance doesnt fix the issue, then it could be the diff.
Getting camber/castor/steering rack/pineapple bushes changed as we speak along with remove/replace of a leaking power steering rack.
I will let you know if i still have a vibration problem afterwards
hrmm
well all my suspension bushes have been replaced and a 4wheel balance & wheel alignment were done yesterday.
Vibration is still there at 100km/h
Went back to the suspension place to double check everything, and he mentioned that if the vibration is felt through the back seat, floor etc then it is a driveline vibration.
Also mentioned that it is the tailshaft as in the r32 its in 2 parts or something and happened after clutch install.
hey guys! i just had a similar prob, i had a gearbox replaced and the car had vibration
at over 80kph, it ended being the centre bearing was shit and the tailshaft needed to be 15mm longer. but the damage also went to the yoke seal on the gearbox.
best thing to do is take it to a driveline specialist. not including the price of the box,
that monkey mechanic who didn't check his work has cost me $1200.
could have bought a rb25det box after all,, :D
excuse my stupidity but where is the centre bearing you speak of?
i have the same exact problem aswell, approx 105km/h and it shakes, only gets worse and you go faster too
have a feeling its the diff or gearbox as it makes a grinding noise between 2-2.5k on each gear aswell AND also can hear a bearing spinning noise (input shaft bearing?) when the clutch is not pressed and its sitting in neutral
tek 01, the centre bearing sits roughly half was between the gear box and the diff... best way to check if it's buggered or not is to through yourself under the car...may need to be jacked up at the rear and push and pull on you tail shaft, if it moves around and clunks it's stuffed... if it stays relativly 'center' it's not you centre bearing... we have a distributer in makcay called hardy n spice.... thats where i got mine from...they seem to know there stuff
sounds alot like your thrust bearing...is it absolutly every gear that it grinds at 2-2.5 k?........ how many K's on the car?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
