tip 1
don't look at the camera's
tip2
the bag you intend to carry your loot off in make sure doesn't have a money symbol on it
tip 3
take your mask of when getting away as not to invoke suspicion :turned:
tip 4
write your demands on a piece of paper so you don't have to speak
I done some ringing around and found out that emmistion testing is 700dollers a pop at regency. You can engineer coilovers but they must have 2,3/4 travel so that puts a lot of brands out, bigger rims can be done but must have tyre size chart sticker on the car(cost more)
After talking to a few Engineers i found out that Emissions testing in adelaide is still going thro some loops but will be sorted out soon
So i recon im going to machine the rb30 of the block lol and change to a stock plenum put the power fc in a stock ecu shell for now
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
