Auto box will be fine.. Get a tight shift kit in to her and she'll be fine. :ermm:
that was my last mod 2 months ago- should have been the 1st mod 2yrs ago
very tight shifting, very very happy with MV's work
worried about the wiring up job tho for the powerfc ecu + pin 51 resistor trick (engine check light) + attessa system (pin 23 I think from power fc ecu to attessa ecu)
but yeah not sure
will get Bostwerks to do the job, but need all the info. got some, but I dont understand electronics lol
:D
hi ;)
my hand hurts so bad from writing out these damn 21st invitations ;)
my knees hurt from walking, sitting, sleeping
wish the wernt in jars.
21 yay ;)
oh to be 21 again
Im now hearing pin 37 on the r34 gtt power fc controlls the attessa throttle position sensor (rather than traction control for the r34 gtt)
so tha should be ok.
just pin 51 and use the zenode trick to pull it to 3.7v from 5v
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
