i like skylines wooooo
lol, i am never attempting to put an aftermarket rear bar on again.
thing p*ss*s me off so much, and now i cant get my bloody side pods bak on.
who wants to spray my rear bar midnight blue and install it for me??????
what brand is it sometimes u get what u pay for with the cheaper ones if its a good brand u should have minimal problems >_<
Just bitching about my unproductive day. Me and Jenkies decide today is that day to put my new intercooler and dump pipe on. Front bar comes off easy as, no problems. Bit of trouble trying to get the stock cooler off.
Decide to have a break before we take it off. glance over to my intercooler box, peel back a bit of packing tape and see "R33 Kit". well now, thats not what i ordered?
so anyway, put everything back together, make sure all bolts are on. ok time for dump pipe.
or, not.
nuts have seized, no chance in hell of getting them off.
so for just under 5 hours of labour, we accomplised:
- found one nut on the cat was really loose, tightened.
- removed thermo fan so cooler core will fit.
lesson for today. pay someone to do it for you.
I'm pretty sure that R32/33/34 intercooler kits are interchangeable as most of them use the factory hot pipe side of the piping and for the cold side you have to cut a hole so there won't be a problem there with lining up as well. Better pull it all back off again.
Might just take it to an exhaust shop and get them to fit it for me. That way i know if they snap a bolt, they fix it. I on the otehr hand, dont have the tools to fix anything major.
no dont coz they will make u pay for the snapped stud.
i have tried that wen i wanted my screamer on and they said nothing about it n i mentioned that sum of the nuts mite be tight n they said if it snaps it not there fault and u have to pay to get it removed.
and if nothing is mentioned about it they will still make u pay! it sucks but they class it as not there fault because they are just doing wat you asked them to do.
Yeah but the mounting brackets that were supplied wont fit.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
