that was a pain in the arse today..i so wanted to hear that thing....just wack some rb25 coils in mate, she'll run sick! LOL
Fresh set of plugs later on today, and she should be ok. Might chuck some fresh fuel in it too.
If she doesnt start, Ill empty the rest of the jerry can on it and take to it with a zippo.....
cheers man, figured if i have to get out anyway, may aswell go somewhere i havent been before :blink:
should know for sure if i have it in no more than 12 weeks, and on a plane in no more than 13 weeks. (going through an agency)
lol, nah she'll be alright.
scandyflick, thats a big step, to pick up everything and take off to canada! Would be a great opportunity...what agency you going through?
i was gonna be dropping everything and moving somewhere anyway, was originally going to be perth, but a friend of mine whos done 3 or 4 working holidays put me onto the canada idea, and it sounds a lot more fun, start over with a clean slate, see a country ive wanted to see for years, should be good.
going through a mob called one world recruitment, they do all the leg work for me, charge a 600 smacker fee, but they practically guarantee a placement in a reasonable timeframe, or they give me a refund.
why you need one champ?
Rebuilding the engine with all forged items, Iv just got a oem nissan water pump for $110 from ebay usa and just wana check what the going price is for the oil pump. I was going to go jun for just over 1k but dont really wana get a custom sump to go with it.
we'll as i told the person that gave me this i will put it up for them but i don't get or agree with tatoo's but hey each to there own
i got given this yesterday buy Ric's Auto Perfection's hairdresser
I got my tat done there, they done a great job on mine, so if anyone is think bout gettin something done i highly recomend them...
If you go anything bigger than a std rb25 pump be sure to restrict oil pushing in to the head.
If you run a JUN pump you will definitely have to look at both restricting oil to the head + providing a rear oil drain from the head to the sump. All of which is a huge stuff around.
A new stock pump is fine. If you feel the need make the step to an N1 pump but do bare in mind even Nissan restricted oil to the head with their N1 motors.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
