Darren the car looks great, especially with those nice deep wheels.
I see that Anthony got back up the front in the night races (we left around 5.30ish)couldn't believe he was as fast at night as he was during the day ;)
Can't wait to see if Greg can pull of the West 1 make series here in he state rounds. Its hard to believe that a car that sounds like a mosquito is so damn fast around the trac, 1.09 with a amateur driver! Tom Drewer is down in the 1.04-1.05 area
I see that Anthony got back up the front in the night races (we left around 5.30ish)couldn't believe he was as fast at night as he was during the day :D
Yeh cheers man.
Yeh Tony is a weapon in that thing, and the only reason he got back up there is we chucked his stupid PPG box out(has blown 3 times in a year now) and chucked in a U Pull It Toyota gearbox special Strat and i got on the friday, and saw him finnish the next 2 races and winning the last!!
We qualified 5th witch was great, but at the end of the session we came off and had to shut her down, worked out the oil return spring had come out and was floating in the sump :P we fixed that up just in time and got to the out grid for the first race and was dripping oil, when we put the sump back on some of the sealant smudged off and didnt seal properly, therefore a oil leak!! Sorted that out for the second race, but had a cooler pipe come off, so we were running atmo, then the last race i think we came from about 15th and finnished 5th, last race was how the rest of the day should have been!!
next meeting is in 3 weeks over the Saturday and Sunday!!
Which group buy and how much Matty?
Angry's group buy on R31 Skyline Club - got it for $175 delivered
Gone for the 8000k H4 as i asked brenton what colour temp he runs in his 32..........so this will be perfect for track by the sounds of it
Found this Stanza R32 Conversion on a thread someone posted on JAPANESE NOSTALGIC CAR... I must give credit to who-ever did th conversion though, even if it is abit whack :(
Thats pretty crazy lol
Anyone know if Bride Ergo seats are ADR approved?
is that a one off group buy
i dont mind that but i like old skool oh and its a 180b not a stanza
*PICS REMOVED* *we dont need to see it a 3rd time*
Dave the Celsior looked the goods at Auto Perfection today, and that was without the tint on it yet!! Had to go in and get my drivers window re done as they were not happy with it as was I!!
cheers dude :D
probably the worst time to see her though, she hasnt been washed since about 4 days before the blowout, and shes been sitting in my dusty as garage ever since then, filthy as. that and the fact thats its jacked up pretty far for the spacesavers benefit... but that being said, it looks f**king hot with the tint on it. :P
have to check out that aristo of yours sometime, toyota photoshoot? :P
cheers dude :D
Yeh well i only really saw it from thru the showroom door, didnt go up close to it, didnt even notice the space saver......LOL Yeh dude its amazing how much tint makes a car look the goods, especially on VIP cars!!
Have you entered AJD?? You should for a bit of fun, I'll prob head over to the pub for lunch and a couple beers while there......LOL
Yeh a Toyota photoshoot would be sweet as!! :D
at this point i think it was, but if theres more interest there may be another one that goes ahead
will ask him though
i'll try and find a link to the thread, but if ya still registered on there steve (i know you are, i have a good memory :P) you might be able to hav a word with Angry and see. - heres the thread: http://forum.r31skylineclub.com/index.php/topic,98894.0.html
what bulb type and K rating would u want?
Edited by Matty 31
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
