now thats a thought hey Pauly still got your cruise note's ;)
yeah i have an idea on where to cruise next i will have to get some maps and check roads :D i will consider one soon when i know i can save some money for petrol'a :D and you have your new car complied
yay!!!!!!!!! :PBJ:
seems ill be keeping my celsior for a while longer, according to the 2 financers my buyer visited, my car is worth at the most, $8000.
theyre gonna keep looking, but im not liking my chances.
whilst it looks very nice and all you might want to change it before i report it and i would have to report you for it based purely on file size the file being 1.2mb im actually surprised SAU let you host it as you av
edit
ill try some more but here is a acceptable edit of it
new avatar ;)
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
