i changed my spark plugs last night. wow that was some serious fun! haha no seriously it was!!
anyway on saturday night i had a feeling to check my 1 cylinder plug dont know why just did. and im glad i did the electrode was melted away! so yesterday i changed them (im so proud of myself lol) to discover that not only cylinder one was like that but also cylinder three. so im guessing that just means that those two cylinders are creating more heat than the others cause they were melted at all.
my god its made a difference though she is heaps smoother now and this morning was the true test. normally when the cold choke is on and you accelerate, it feels like something is holding the car back from getting speed, but then it will allow the car to speed up (its weird) but this morning it didnt happen! i originally brought it down to the Power FC cause the spark plugs that were in there had only been put in just before Extreme Horsepower last year, so i didnt even think that it could have been the sparkies at all.
i know its probably not the best pic, but the sparkies on the left was taken out of cylinder three and the one on the right from cylinder five. just to show the difference.
Could it be that it was tunned for no2 and it doesnt run it all the time
With N20 you shouldn't be melting the strap.
Cara. Do you run a wet or dry system?
Also steer clear of platinum plugs with n20. Use good old coppers or iridium.
hey guys
ive spoken to my tuner and i have also come up with some ideas on why the sparkies have melted.
my tuner has said that she could be running to lean on the top end, which means if i have to much open throttle i could do damage to the engine. im gonna try and book her in this week. im really worried about it cause i dont want to have damaged the pistons let alone blow my engine :( its a sickening thought that there could be damage already done because i dont know how long the spark plugs have been like that.
the ideas ive come up with why they have melted is the nos (plugs just couldnt handle it), extreme detonation (which was happening), the mixtures isnt right at the moment, blockage somewhere, i changed the o2 sensor so im thinking that might be a reason too, i havent really done much to the engine of recent other than the rocker cover gaskets and the o2 sensor. before that the power fc, gtt injectors and nos was put in
there is so many possibilities on why this could have happened. im not pointing the finger at my tuner for doing a crap job cause i know he knows what he is doing.
and Cubes its a wet system.
mind you guys her last tune was in december (maybe over due big time)
it hasnt been detonating since the new O2 sensor was put in
ive heard my car ping before, but that was just a matter of getting the timing put back to fix it
ive got her booked in for sat morning so ill just drive her nicely until then.
good luck
Im waiting for my chip to be mapped, and the chip adapter to arrive from japan
once thats all sorted and a tune/map is written on the chip, I'll get my safc/sitc adjusted for hopefully the final time.
with the remap Im hoping for 205awkw / 215rwkw
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
