yeah, the guy my mate is gettin the sus/axles/brakes thru just needs a stud pattern. 5x114.3 gives us the most flexibility (ford, nissan, toyota, mazda, etc).
also will be in contact regardin them stockies :happy:
i hate cars sometimes!
Car is in getting about $1000 worth of work done to her :happy: Im carless until at least wednesday if not longer :D
All new hoses.. thermostat.. cooling system flushed and new coolant, amongst other things.
flick, the hose that gave out on you sounds like the one i had give out a couple of times. cost me about 600 bucks over both times to just have them replaced. woulda lost coolant without knowing it? not until it decided to boil over?
well temp never really changed at all. I didnt have a clue anything was wrong until i got to work and saw the coolant pissing out everythere and steaming! The hose was pretty much split in 2 when i got to the mechanics.
Decided to replace a few other hoses along with it, cos theyre sure to go very soon too
:D i used to work for Olympic Trailers :) making 6x4 5x8 custom and horse float side's and tail gates
in a day from nothing to complete chassis i used to make 2x 6x4 that's cut and bend all my own materials
oh, and a small note
the process is started, my trailer is about to be started :P. Once its built, my mate has said he will be happy to build more (and to your specs). Designs are ADR approved, so will be easy to get passed through a regency inspection to gain registration as well
i'll have my trailer by the time shepparton comes round (give or take a week or two prior to having to go)
I would't mind having a look at that when its finished Matty, as i use to build custom made trailers for 5 years, oh and you dont need to take it to regency to get rego, just need to take it to a registerd trailer manufacture for a quick visual inspection to get it rego'd
hears a pic of one of my old creations, full box chassis, full tilt, winch, side mounted spare wheel, hide away alloy ramps, led lights, 2 pack paint. :bunny:
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
