i might be behind the wheel of an rb20 shortly, my first one! wooo.
well ive driven an rb20 before, but never owned one.
You swapping the Onevia for a Skyrine there Tim?
I reckon you'll find the 20 lacking in lowdown grunt after a VCT SR, but 8.5k rpm = teh win :D
Legnum transmission is now replaced, WOOHOO! :)
I'll be hitting up the Charity cruise on Sunday. If anyone else from here is going, come up and say hi! :) Will be there with a few other Legnum owners too, so don't be scared, we don't bite (hard) :kiss:
sacked
Im not turning up to work as Im in too much pain
its a mutual thing I suppose, dont feel good about it, but the bosses are imploring me to get onto the DSP and get myself back on track. its what I need to do, so here goes................
oh :woot: now we feel dirty youve gone and left us for the LGA :) Legnum Australia
I'll be hitting up the Charity cruise on Sunday. If anyone else from here is going, come up and say hi! :woot:Will be there with a few other Legnum owners too, so don't be scared, we don't bite (hard) :kiss:
Hey Brendan chin up dude you know you only got sacked so you dont have to wait 13 weeks to get anywhere with Centerlink... and dont think of centerlink as a dirty word ok your one of the 2% that actually use the system for which it was initially setup for
I just got sacked after working here for 11 yrs
hmmmmmmmm
EDIT
oh yeah ive booked into boostworx for my 5stud conversion drifteks here i come :)
oh yeah ive booked into boostworx for my 5stud conversion drifteks here i come :P
oooooooo aaahhhhhh!! fill us in steve!! what size drifteks are they? what width tires you goin? colour ?
i recon it will make a substancial difference looks wise
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
