Lol i pay out most female drivers, cos seriously so many of them cant drive for shit! Love the ones doing their make up etc as they drive.
Yes im paying out my own 'kind' here but most of them are just baaaaaad drivers.
I know how to drive :whistling:
I just hate relying on others, like the freedom of having my own car
I haven't driven mine for 2 months.. :P
Laid up in the drive with with bits off waiting for some other bigger lumpier bits. :D
n/a sucks I really miss the mid and top end rush.
You know its been too long when a VN commodore and Mazda 3 starts to feel like its got some punch.
no need to miss boost buy a little turbo charade :P with a few mods they can run 14 down the quarter mile
Iv been in charade turbo and bloody hell they go alright also im a fan of the tx3 and et pulser both very zippy cars :P
Had a ET back in the day, ran 7psi low boost and 14psi high boost, I bet you know which was run the most......... Went thru 3 gearbox's, they are shite!! The Tx3's arent too bad, but always remember Jr who used to work at ET back back in the day with Marky, he had one and shat the box out also, unless you put a 4G Evo motor in them, then they rocket, was a black one out at Mallala the other week............
Apparently that black tx3 has full evo running gear
haha bunny, well ill forgive u :)
So just got my car back from the mechanics after a week and wow feels like a dream to drive! So much better! There isnt one hose under the bonnet that wasnt replaced.. few new pipes (cant remember exactly which ones) cos they were corroded. New thermostat.. cooling system completely flushed, cleaned and refilled. Engine bay and all underneath professionally cleaned and all shiny!
Shame to sell it now lol
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
