^^ really? will it stick??? was looking for the dacals that stick on the cap themselvs but could only dind transformer prints in black, not thanks! lol
i need some brake paint to, so ill have a look......has any one else painted centre caps?
Edited by craig R33
yeah currently 4000kms into the current Motul turbolite 8100 10/40w
got 2 for one a year ago.
hhhhhm not sure, might just let the tuner take his pick :D
Motul ftw. used to run it in the silvia for ages. Not sure what my mechanic uses on my line, Mobil 1 im pretty sure.
what should I use
have 5L of both Castrol Edge 0/40 and Motul turbolite 10/40
Pffff when the oil is only in there for 5k kms it prob wouldn't matter too much, they are both a similar grade anyways!!
Castrol are also a decent "brand name" so whatever really!!
Your engine wont go bang because it has Castrol in it as aposed to Motul, But it will go bang if you take too long to choose and you run out of oil!!
Edited by Deluxe
^^ Would if i didnt have a work promo night tonite at the convention centre - 3 course meal and all you can drink, alcohol + softdrink. + entertainment (last year was that cirque de solai thingo) + lots of prizes. Wooh!
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
