went for a Hills run
187kw is just dandy :P
get rid of the exhaust restriction, retune (all under $500)
and yeah she'll be right
200 is what Im after, and it'll happen
next tune, next tune
Im thinking replace the cat converter with a big body one, welded on, with a new cat back system replacing the small "hotdog" thingy to the muffler
just jap bellmouth dump
metalcat? bigbody cat
gtr kakimoto racing mufffler
might be loud
lol
:P
so.. looks like my car is sold pending payment! Sad but happy too. Will be nice to be out of debt and live more comfortably but sad to see her going. It is going to a good friend of mine though, who is a member on these forums - although not very much at the moment.
that said, ill still be around, cant get rid of me from here that easy. What ever i buy will still be adorned with SAU stickers though :P
    • Thank you for the feedback bro. Looks like it’ll have to stay off the road till it gets an ecu
    • Only if you do not You will not be able to drive it with any serious load without risk of it pinging, which will either slowly or rapidly kill it, depending on how bad it is.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
