drop me a pm with what your after and i'll get a price for u.
Im looking at getting some 700cc sards for my GTR from a Trader on here for $699, but if you know some one who can do it cheaper..... Well maybe you would be kind enough to hook us up.... :P
20 Ways To Maintain A Healthy Level Of Insanity
1. At Lunch Time , Sit In Your Parked Car With Sunglasses on and point a Hair Dryer At Passing Cars. See If They Slow Down.
2. Page Yourself Over The Intercom. Don't Disguise Your Voice.
3. Every Time Someone Asks You To Do Something, a sk If They Want Fries with that.
4. Put Your Garbage Can On Your Desk And Label it ' In'.
5. Put Decaf In The Coffee Maker For 3 Weeks Once Everyone has Gotten Over Their Caffeine Addictions, Switch to Espresso.
6. In The Memo Field Of All Your Checks , Write 'For Smuggling Diamonds'.
7. Finish All Your sentences with 'In Accordance With The Prophecy'.
8. Don't use any punctuation.
9. As Often As Possible, Skip Rather Than Walk.
10. Order a Diet Water wh en ever you go out to eat, with a serious face.
11. Specify That Your Drive-through Order Is 'To Go'.
12. Sing Along At The Opera.
13. Go To A Poetry Recital. And Ask Why The Poems Don't Rhyme?
14. Put Mosquito Netting Around Your Work Area and Play tropical Sounds All Day.
15. Five Days In Advance, Tell Your Friends You Can't Attend Their Party Because You're Not In the Mood.
16. Have Your Co-workers Address You By Your Wrestling Name, Rock Bottom.
17. When The Money Comes Out The ATM, Scream 'I Won! I Won!'
18. When Leaving The Zoo, Start Running Towards The Parking lot, Yelling 'Run For Your Lives! They're Loose!'
19. Tell Your Children Over Dinner, 'Due To The Economy, We Are Going To Have To Let One Of You Go.'
Tangles - this might be the right "cat" for you :sick:
Link Here
This product does not perform the exhaust cleansing function of a catalytic converter in any way. Use of this product on the road might violate countless laws and prevent your car from passing emissions, therefore it is recommended for offroad and show use only.
:P:sick:
Edited by Damo_R34
Im looking at getting some 700cc sards for my GTR from a Trader on here for $699, but if you know some one who can do it cheaper..... Well maybe you would be kind enough to hook us up.... :)
Hey mate, the price i found of 590 didnt include the plugs :cheers:.
The price the includes the whole lot delivered would be $630
If you like to go ahead pm me and i'll put a order in.
Hey mate, the price i found of 590 didnt include the plugs :cheers: .
I'll PM ya in a couple of weeks just gotta pay off some bills first,
cheers for that champ :)
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
