Yeah, Adrian is saving for Il Divo
Mate i got the cd, i really do and no shit it sets the mood and it gets the chicks doing anythink in bed from A to Z. I have 14 years good luck from poping 2 catholics and that ant no easy job its all part of the 7 year rule catholics,lesbean and female police= 7 years good luck for each one :ermm:
ROFL carl
what was teh fine
teh fully sic skidz yo
LOL yeah, i drove around a corner into an empty car park in a less than sedate manner and i created "undue noise" :ermm: then while waiting in a drive thru to get my dinner, i was greeted by a gentleman in blue who wished to have a brief conversation about my skills
he was a nice guy really, it could have been far worse
If you're in a drive thru, you're on private property and can have the fine dismissed as the officer was out of his jurisdiction giving you a fine while on private property. I would contest this in magistrates court.
-D
Poo!
I went to fit my Slide stage 2 turbo today. I need some braided lines made up. Looks like the Stag is off the road for a while.
Good thing I have two stags then :ermm:
so, started dummying mounting positions for my amp about an hour ago.
then i noticed that my 'complete' system is not as complete as i was assured it was.
no remote volume controller for the amp.
and the amp isnt what i needed. its a mono. to power 2 subs.
i think i shall have to call jb. im quite pissed off about that.
not bad if you have a spare $1500-2000 and i dare say you still might not win, i dont think this private property is really true
-D
-D
I realise this and it did cross my mind to mention it, however the time and effort that i would have to go to to get a $128 fine that has no demerit points removed is not worth the headaches. Also my entrance to the carpark was not exactly textbook, so he could easily bring that up... I consider myself lucky, cos he could have easily defected me and done much worse.
Absolutely its true. If you get followed and you pull into private property, they cannot legally cite you as you're not on public roads. There have been many instances of police getting reprimanded for leaving their juridiction. Which if you're a traffic cop, is the roadways. I would only contest something in court I know I'm going to win, and that certainly would be one of them.
-D
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
