Yeah, Adrian is saving for Il Divo
Mate i got the cd, i really do and no shit it sets the mood and it gets the chicks doing anythink in bed from A to Z. I have 14 years good luck from poping 2 catholics and that ant no easy job its all part of the 7 year rule catholics,lesbean and female police= 7 years good luck for each one :ermm:
ROFL carl
what was teh fine
teh fully sic skidz yo
LOL yeah, i drove around a corner into an empty car park in a less than sedate manner and i created "undue noise" :ermm: then while waiting in a drive thru to get my dinner, i was greeted by a gentleman in blue who wished to have a brief conversation about my skills
he was a nice guy really, it could have been far worse
If you're in a drive thru, you're on private property and can have the fine dismissed as the officer was out of his jurisdiction giving you a fine while on private property. I would contest this in magistrates court.
-D
Poo!
I went to fit my Slide stage 2 turbo today. I need some braided lines made up. Looks like the Stag is off the road for a while.
Good thing I have two stags then :ermm:
so, started dummying mounting positions for my amp about an hour ago.
then i noticed that my 'complete' system is not as complete as i was assured it was.
no remote volume controller for the amp.
and the amp isnt what i needed. its a mono. to power 2 subs.
i think i shall have to call jb. im quite pissed off about that.
not bad if you have a spare $1500-2000 and i dare say you still might not win, i dont think this private property is really true
-D
-D
I realise this and it did cross my mind to mention it, however the time and effort that i would have to go to to get a $128 fine that has no demerit points removed is not worth the headaches. Also my entrance to the carpark was not exactly textbook, so he could easily bring that up... I consider myself lucky, cos he could have easily defected me and done much worse.
Absolutely its true. If you get followed and you pull into private property, they cannot legally cite you as you're not on public roads. There have been many instances of police getting reprimanded for leaving their juridiction. Which if you're a traffic cop, is the roadways. I would only contest something in court I know I'm going to win, and that certainly would be one of them.
-D
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
