i might clean my cooler too... cant hurt, might paint the sucker too..
i cleaned my afm the other week, and that seemed to give me a tiny bit moar response.
the hardest part of getting ur front bar off is getting ur headlights n indicators out to get to a couple of the bolts
is a r34 front conversion on a 32 legal?
i dont know 4 sure but there are quite a few sil80 and 1via 's around
also one of my old mans mates told me that a guy got a mini and put another mini
front, on the back. Appenarenty there were complants becouse people got confused
about which way the car was traveling and all the cops asked him to do was put a sign
on the back saying "BACK OF CAR" but that was a long time ago....
On a R32 you should only have to take out the front indicators to get to screws. Should take no more than 10 minutes to get the bar off.
thats right... its been a while, i could just remember taking some lights out to get to those screws.
i have been a torrent whore this weekend. i have downloaded 21Gig... and no... none of it is pr0n
for Pete i got sick of mucking around will make it better later
[img=http://users.bigpond.net.au/madaz_rx8/sigs/sled.sig.1.png]
will actually remake 100% that was prolly 1hr or cutting editing and making a fail sig :D
Hey all,
I recently got a R33 skyline from interstate and have been having a nightmare getting it through regency so I need some advice from you guys. One of the faults that regency found was - "Compliant steering boss kit to be fitted/ proof of compliance to be provided". I currently have a HKB boss kit which i do believe is made specifically for R33's so it is compliant then right?? Also how would I prove the HKB boss kit is compliant :S. Any suggestions would be great
Cheers
Franky
well i got my car tuned a few days ago and safc2 tuned i was surprised with what i got
mods done:
standard turbo
standard fuel pump
standard dump pipe
standard injectors
impul ecu
3" turbo back exhaust
fmic
SAFC2
splitfire coil packs
stage 2 shift kit (mike at mv's)
Automatic Transmission
made 198.9rwkw on 9/10psi
so i thought i would share my results with yas coz im bored right now lol.
cheers
Allan
Edited by R334door(s2)
even if your aftermarket wheel is ADR approved still wont pass regency
they are very picky @ what we take our cars over the pits with i suggest finding a standard R33 wheel
and welcome to SAU
Thanks Luke :laugh: hopefully i feel bothered to work on it some more tonight most of my sigs are learn as i go then i forget how to do things when it comes time to do it again :laugh:
Nice one Allan bet its more fun to drive now :laugh:
Hey all,
Cheers
Franky
eeeewwwww, whats with the new banner? ^^^^^
LOL was my initial thought too
im glad i have an extention on FF that blocks out the ads LOL, opened this site on my linux pc and saw fox symes plastered all over the place.... shut the fkr down, n now im back on trusty (?) old windows
/sigh
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
