i might clean my cooler too... cant hurt, might paint the sucker too..
i cleaned my afm the other week, and that seemed to give me a tiny bit moar response.
the hardest part of getting ur front bar off is getting ur headlights n indicators out to get to a couple of the bolts
is a r34 front conversion on a 32 legal?
i dont know 4 sure but there are quite a few sil80 and 1via 's around
also one of my old mans mates told me that a guy got a mini and put another mini
front, on the back. Appenarenty there were complants becouse people got confused
about which way the car was traveling and all the cops asked him to do was put a sign
on the back saying "BACK OF CAR" but that was a long time ago....
On a R32 you should only have to take out the front indicators to get to screws. Should take no more than 10 minutes to get the bar off.
thats right... its been a while, i could just remember taking some lights out to get to those screws.
i have been a torrent whore this weekend. i have downloaded 21Gig... and no... none of it is pr0n
for Pete i got sick of mucking around will make it better later
[img=http://users.bigpond.net.au/madaz_rx8/sigs/sled.sig.1.png]
will actually remake 100% that was prolly 1hr or cutting editing and making a fail sig :D
Hey all,
I recently got a R33 skyline from interstate and have been having a nightmare getting it through regency so I need some advice from you guys. One of the faults that regency found was - "Compliant steering boss kit to be fitted/ proof of compliance to be provided". I currently have a HKB boss kit which i do believe is made specifically for R33's so it is compliant then right?? Also how would I prove the HKB boss kit is compliant :S. Any suggestions would be great
Cheers
Franky
well i got my car tuned a few days ago and safc2 tuned i was surprised with what i got
mods done:
standard turbo
standard fuel pump
standard dump pipe
standard injectors
impul ecu
3" turbo back exhaust
fmic
SAFC2
splitfire coil packs
stage 2 shift kit (mike at mv's)
Automatic Transmission
made 198.9rwkw on 9/10psi
so i thought i would share my results with yas coz im bored right now lol.
cheers
Allan
Edited by R334door(s2)
even if your aftermarket wheel is ADR approved still wont pass regency
they are very picky @ what we take our cars over the pits with i suggest finding a standard R33 wheel
and welcome to SAU
Thanks Luke :laugh: hopefully i feel bothered to work on it some more tonight most of my sigs are learn as i go then i forget how to do things when it comes time to do it again :laugh:
Nice one Allan bet its more fun to drive now :laugh:
Hey all,
Cheers
Franky
eeeewwwww, whats with the new banner? ^^^^^
LOL was my initial thought too
im glad i have an extention on FF that blocks out the ads LOL, opened this site on my linux pc and saw fox symes plastered all over the place.... shut the fkr down, n now im back on trusty (?) old windows
/sigh
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
