Yeah man still got original injectors in there and still have to get remap from jeff from turbo tune. That was running at 12 psi but as adrian said I'll wind it up to 14 pound for the next dyno run and while he does the remap so i feel a little safer. I was just curious what i was running so i got a printout.
sounds good scott......just be carefull if you're planning on running 1bar boost on ceramic wheels......it's not the the turbo dying that you have to worry about but the bits they may find their way into the combustion chambers :thumbsup:
SLED,
Its only the 26's that have the issues with sucking ceramic back in to the motor. :banana:
Providing EGT's are kept in check with a good tune and no track days 14psi is all good on the stocker rb20 turbo.
There will be bugger all increase in peak power going from 12-14psi; its the mid range that will sit up and feel alive; transform the whole car in comparison. :thumbsup:
very impressed with my car through the hills last night, Stayed in forth 90% of the time with fantastic low down pick up, Pulls like a f*kn freight train considering the shitty tune. Very loose in the arse end. Ii want a GTR! I used about 30 litres of fuel in about an hour LOL! Once again, EBC greenstuff are fantastic.
Edited by Ryanrb25
I hear ya Ryan.....mine wasn't too bad in that department when I did the hills run with my mates 4WD Porsche & Maserati but I double hear ya on the fuel issue!!
yea flat 10.2:1 AFR's arent good for economy.
Was considering putting 3540 on the 25 to crack some big numbers but response like 14psi at 2000rpm is great for those exits.
adrian, sorry to lead you in the wrong direction on the way home hahahaha...lucky i realised when i did!
Edited by Ryanrb25
ahhh ok....I thought they had ceramic wheels too
They do :thumbsup:
For what ever reason the RB26's suck the ceramic back in to the motor where as the single turbo's never do. Most likely a little to do with manifold design and possibly cams.
At 2k? :banana: Thats better than mine; got dyno sheet?
Mine makes an 1psi off idle; by 2000rpm its around 4psi, 2500rpm 8psi and 3000rpm 19+psi.
?? did you come across police
who got defected tonight on our hills run??
wasnt luke was it? hmmm...
they are but they dont get sucked in the motor Joel is saying
They do :thumbsup:
thats wierd isn't it....I wonder if that's more the exception than the rule....what happens to the bits when they do fly apart then?
One theory could be that due to the cam overlap the bits make their way through the inlet then straight out of the exh valve before the bits get combusted.....poor cats if that is the case!
Just to clear up, Dan (Inline_6) got pulled over at the end of our cruise last night, but the cop just pulled a skyline over for the hell of it coz her boyfriend is on SAU! No defects, no inspection. Was a good night tho, i DEFINATELY need some better light globes, just cant see sweet FA without highbeams.
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
