$300 for resonator, $200 for fitting and the junBL's were from the forum here for $450 for the pair (but they originally came from exh tech anyhow)...
Probably gonna get custom dumps, a barrel muffler and a high flow cat from them once I get my new turbos...
-D
Oh no shit no shit. I might go down there and see what he can do for me :banana:. Thanks alot.
I just went and hade a look at this fairlane zj that i won on ebay the add said it was in perfect con,one owner,on gas a small amount of surface rust on the inside of the bottom of the doors(common in the Zj to Zl fairlanes) and runs like a dream. The doors didnt have surface rust they were rusted out and in every door the motor was running crap a million leaks and sounded like it was running on 5 cylinders the gas tank was out of date by 1 year and the guy hadent even change the car in to his name from first owner. He made me wast my time by driving 40mins with a shitload of crap add so i wasted his time by saying il be back in 20mins with the money lol
Does anyone know how to change the injector values on a Power FC, or can anyone do it for me, will pay cash. I have my new 700cc Sards sitting in my spare room, just begging to be put in.
how much did the sards cost ya? Did you get fitting collars or a new fuel rail, and if so how much she set u back?
-D
you don't Matty :) best way to send multiple PM's is to make your list in txt pad exact copies of people's user names then make your pm and add first name then send then hit back on your browser and change name and repeat till all people on the list have been done
i needa find someone to put my lowered springs in before then too!
any one know of a cheap place to do it?
i pick them up friday, so its install only
Craig, ill do it cheap for you and youll learn as we do it if you want!!! I have everything to do it.
Ive done this a few times, I did it on my own car, you have to work out latency etc...Ill work it out and get back to you what to change if you want.
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
