Anyone wanna sell me an R34 Power FC? I hear alot about modding them to suit your application, so rb26 being modded to suit rb25 neo. Whats the go?
Can't mod the rb26 pfc to suit the Neo as they are a different plug. Could possibly do it I suppose if you grab a 25 or 26 plug and then painstakingly swap each individual pin. :P
NEO engines have variable valve timing, so Im not quite sure that they will fit rb26's... I dont believe there were any rb26's released with VVT... will probably need a special ECU to do VVT.... possibly easier to just remap the stock ecu
-D
-D
Nah its not variable.. Its the same as the r33 but 'apparently' smoother in its transition; of which comes down to the solenoid mechanism its self.
You can use a simple $34 window rpm switch imported from the US from a mob that I know of. Its basically a NOS switch; switch on at x rpm then switch off at y rpm.
yea thats what i was gonna say lol
people usually use rpm switch when they use an rb20 remapped ecu on an rb25.
hrm news to me, i always thought they were some special type of comp controlled head ...
will know better next time :P
-D
On a totally unrelated topic, theres a"1993 GTR turbo skyline" in the paper for $10,000. im thinking its not a gtr, so i messaged him "hey mate, is the gtr still for sale?" i get back "yes". hmm, guess ur keen to sell then
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
