thanks for the input guys. and thanks guy i might take you up on that. ill call you if need be.
thanks for your input cubes!
comp has 4 gig ram, core 2 extreme(quad core), 768 3d card(overkill) and most games i can crank up.. a few stall but with grid it glitches and freezes up like crazy. running 1920x1200 res... hoping xp will fix this issue and just not happy with vista on the whole.
I have alot of mates who use vista and haven't heard of the issue's your describing i would almost put it down to being a dell
just because they claimed it was the fastest ns whatever if they used inferior parts for memory or graphics card your going to end up with alot of problems
i also know nvidia aren't that great with there drivers so it may be a case of searching if other people are experienceing the same problems with dell systems or the same graphics drivers
just as an example with the game grid i was having corrupted gfx on the demo so i rolled my drivers back and was all good now i have the full version and even newer driver haven't seen that problem since
*cough* Nvidia drivers are probably the most solid drivers out there on the market. If you're using beta/alpha drivers then you're bound to have issues, but historically Nvidia have had much better drivers than ATI. That said, I've owned ATI and Nvidia and both have had isolated incidents with driver releases from time to time...
-D
3d card is nvidia 768 x 16 8800 ultra. how would i update drivers?
will try that before i whipe it.
www.nvidia.com
go to download drivers
enter 8800 ultra as the gfx type. download the release that suits your operating system (vista)
Once downloaded, Run it. Voila, new driver installed.
-D
hmmm moving house sucks.
me and the missus are putting our unit up for rent, after spending mega bucks on a re-furb.
it went into the paper on sat, and the net >click here<
we have 3 couples coming through it tonight for an inspection!
one couple has offered more then the weekly rent, they want it so bad!
but the real estate agend doesnt like the look of them lol.
its all good though saving more money FTW
moving back with missus mum FTL
having a double garage all to myself FTW
real estate agent fees, FTL
I'm in the talks at the moment with the bank ... looking at bidding on a massive 4 bedroom home (with 2 double garages) on a huge block of land :(
If I get that house, I'm def throwing a house warming party!!!!!
*fingers crossed*
Well for what its worth my specs..
All using the latest drivers from the respective websites.
Gigabyte EP35-DS3
Gigabyte 8600GT @ 1680x1050
All rock solid memtest (test 5 and 8 for 24hrs) and prime stable.
Runs Grid fine no hang ups or stutters.
I had a slight issue when I was running a 400fsb where it was rock solid in prime and memtest yet BF2 would still randomly drop to the desktop. Dropped it back to 333 with the same overclok and its now fine.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
