ha ha ha ^^ ill be the camera man..
wohoo 800 posts. most of them stupid and meaningless! lol
oh well.
im off to bed, gotta early meeting tomorro morning :O
Edited by craig R33
rad33... When taking it for a bit of a boot take note of the peak afm volts... :(
Hows the highflow feel compared to the stock turbo at 14psi? stock turbo feel like an easier quicker street turbo on the rb20? When I had a larger turbo on my rb20det it felt like it was slower to 100km/h and required lots of rev's off the mark and only once in third was it quicker.
The sad fact is you'll always get used to the power.. 250rwkw+ feels quick but you quickly start to think it could feel quicker. :O
Oh and i just bought some more RAM for my laptop, love the engrish on the back
"Quality is one of utmost important winning formula for Gingle's leading position in memory field. Gingle has developed a quality system and nonetheless we continue to refine our quality management process to ensure customers receive quality solutions cost effectively"
Edited by Damo_R34
Hey Damo! Yeah it is hard living with only 200+kw, so thats why im now pushing 300+awkw! :O
hahahah Ben don't tell people how much that cost you :D and the saga that has gone with it :P
Ha! Yeah ... the cost of absence and headaches ... one pissed off Nene! :) Shall I go on Ben? :(
hahahah Ben don't tell people how much that cost you :) and the saga that has gone with it :D
ha ha i know steve, i literally could have bought another car for the cost of the upgrades, but its the sacrifice we make for more power!
<------ Awwwww, I got another cute bunny! :D
Time to find another offensive avatar :O
I'm surprised the last one lasted as long as it did. :P
ba ha ha hanice bunny fag! jokes, isnt that two bunny's? now u can make a pair of slippers! :(
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
