ha ha ha ^^ ill be the camera man..
wohoo 800 posts. most of them stupid and meaningless! lol
oh well.
im off to bed, gotta early meeting tomorro morning :O
Edited by craig R33
rad33... When taking it for a bit of a boot take note of the peak afm volts... :(
Hows the highflow feel compared to the stock turbo at 14psi? stock turbo feel like an easier quicker street turbo on the rb20? When I had a larger turbo on my rb20det it felt like it was slower to 100km/h and required lots of rev's off the mark and only once in third was it quicker.
The sad fact is you'll always get used to the power.. 250rwkw+ feels quick but you quickly start to think it could feel quicker. :O
Oh and i just bought some more RAM for my laptop, love the engrish on the back
"Quality is one of utmost important winning formula for Gingle's leading position in memory field. Gingle has developed a quality system and nonetheless we continue to refine our quality management process to ensure customers receive quality solutions cost effectively"
Edited by Damo_R34
Hey Damo! Yeah it is hard living with only 200+kw, so thats why im now pushing 300+awkw! :O
hahahah Ben don't tell people how much that cost you :D and the saga that has gone with it :P
Ha! Yeah ... the cost of absence and headaches ... one pissed off Nene! :) Shall I go on Ben? :(
hahahah Ben don't tell people how much that cost you :) and the saga that has gone with it :D
ha ha i know steve, i literally could have bought another car for the cost of the upgrades, but its the sacrifice we make for more power!
<------ Awwwww, I got another cute bunny! :D
Time to find another offensive avatar :O
I'm surprised the last one lasted as long as it did. :P
ba ha ha hanice bunny fag! jokes, isnt that two bunny's? now u can make a pair of slippers! :(
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
