yeah he is where i got the idea from :blink:
the Blitz 555's are $690, will i need an aftermarket fuel rail for them or new regulator?
Don't be WEAK!!!!
Go for a set of 800's so you can tune it for E85 as its now available in SA and soon to be rolled out everywhere. :)
Don't be WEAK!!!!
Go for a set of 800's so you can tune it for E85 as its now available in SA and soon to be rolled out everywhere. :blink:
haha Joel loves his E85. my worry is the availability, if im running close to empty, and there aren't any e85 servos around?
Don't tune for it just yet.. But at least you know you will have the head room in the injectors when your ready to. :D
A set of sard twin spray 800cc's pull up fine and return stock economy. Don't buy single squirter's they are crap under 2k.
You need around 35% more injector with E85. So for ~300rwkw you will need ~700cc injectors with E85.
Depends on the dyno but 550's generally hit 80% at around 300-310rwkw. + the E85 as you can crank some timing in to it and it just won't ping will make another 30rwkw odd.
Just sucks 34 injectors are so expensive in that size. ;)
yeah he is where i got the idea from :D
Mate, Nismo gear goes straight in without any different plugs, fuel rails n all that bullshit...
Cubes, whats the go with E85 eating at your fuel pumps, lines, injectors? Im curious!
im now officially an unemployed bum ;)
but i must say working for the gov was the best job i ever done
best day working there was handing out free suncream to people at the big day out giving me a free ticket into bdo and getting paid my normal accounts wage while there :D boo ya
feel free to let me know if you hear any accountant type jobs going.
Edited by Inline 6
Yeah i read that too Ryan, apparently even the fuel tank should be changed the stainless steel, and you have to remove all rubber, foam etc from the fuel setup.
bah its load of crap. :D
Ethanol actually cleans. Not quite as good as water injection but damn close.
Unless you leave it in your tank for 1+month only then does it begin to absorb water.
Unless you have an aluminium fuel tank you don't have to worry. ;)
Bosch fuel pumps are designed with ethanol in mind.
The 'only' issue E85 has is with 'old' fuel line.
I've replaced my fuel hose from the tank to front with suitable hose from pirtek cost me a total of $40. These cars are 10+ years old now its worth while replacing fuel hose regardless of fuel especially when base fuel pressure (36-40psi) + boost (20psi) = up to 60psi of pressure running through 10+year old often surface cracked fuel hose = disaster waiting to happen.
Cubes, whats the go with E85 eating at your fuel pumps, lines, injectors? I'm curious!
Dino fuels leave deposits, so when you change to Bio fuel it will clean out the system. Its a food idea to replace your fuel filters regularly for the first few thousand k's (ie at 2K and again at 5k)
As for fuel lines, if you still have the original rubber ones replace them (they are overdue anyway), and if you have replaced them in the last 2 years you should be fine. Its the same argument for E85 as Bio-Diesel, much of it is scare tactics, other bits are common sense.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
