yeah he is where i got the idea from :blink:
the Blitz 555's are $690, will i need an aftermarket fuel rail for them or new regulator?
Don't be WEAK!!!!
Go for a set of 800's so you can tune it for E85 as its now available in SA and soon to be rolled out everywhere. :)
Don't be WEAK!!!!
Go for a set of 800's so you can tune it for E85 as its now available in SA and soon to be rolled out everywhere. :blink:
haha Joel loves his E85. my worry is the availability, if im running close to empty, and there aren't any e85 servos around?
Don't tune for it just yet.. But at least you know you will have the head room in the injectors when your ready to. :D
A set of sard twin spray 800cc's pull up fine and return stock economy. Don't buy single squirter's they are crap under 2k.
You need around 35% more injector with E85. So for ~300rwkw you will need ~700cc injectors with E85.
Depends on the dyno but 550's generally hit 80% at around 300-310rwkw. + the E85 as you can crank some timing in to it and it just won't ping will make another 30rwkw odd.
Just sucks 34 injectors are so expensive in that size. ;)
yeah he is where i got the idea from :D
Mate, Nismo gear goes straight in without any different plugs, fuel rails n all that bullshit...
Cubes, whats the go with E85 eating at your fuel pumps, lines, injectors? Im curious!
im now officially an unemployed bum ;)
but i must say working for the gov was the best job i ever done
best day working there was handing out free suncream to people at the big day out giving me a free ticket into bdo and getting paid my normal accounts wage while there :D boo ya
feel free to let me know if you hear any accountant type jobs going.
Edited by Inline 6
Yeah i read that too Ryan, apparently even the fuel tank should be changed the stainless steel, and you have to remove all rubber, foam etc from the fuel setup.
bah its load of crap. :D
Ethanol actually cleans. Not quite as good as water injection but damn close.
Unless you leave it in your tank for 1+month only then does it begin to absorb water.
Unless you have an aluminium fuel tank you don't have to worry. ;)
Bosch fuel pumps are designed with ethanol in mind.
The 'only' issue E85 has is with 'old' fuel line.
I've replaced my fuel hose from the tank to front with suitable hose from pirtek cost me a total of $40. These cars are 10+ years old now its worth while replacing fuel hose regardless of fuel especially when base fuel pressure (36-40psi) + boost (20psi) = up to 60psi of pressure running through 10+year old often surface cracked fuel hose = disaster waiting to happen.
Cubes, whats the go with E85 eating at your fuel pumps, lines, injectors? I'm curious!
Dino fuels leave deposits, so when you change to Bio fuel it will clean out the system. Its a food idea to replace your fuel filters regularly for the first few thousand k's (ie at 2K and again at 5k)
As for fuel lines, if you still have the original rubber ones replace them (they are overdue anyway), and if you have replaced them in the last 2 years you should be fine. Its the same argument for E85 as Bio-Diesel, much of it is scare tactics, other bits are common sense.
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
