Just got back from watching The Dark Knight - what an awesome movie I highly recommend everyone go watch it :)
Yep just got back from watching it at the drive in. Fkn unreal. Ledger was awesome but the whole movie was pretty good, it unravelled quite nicely. Bring on Batman 3
-D
there's actually a thread for changing your user name somewhere, you just gota post what you want it changed to and when a mod gets time he can change it for you.
don't think they like making regular changes so choose wisely :) and wait for people to ask who the hell are you
hahaha so how many times have u changed yours Dan?
i was just wondering how long it takes to send out letters within the state? because i'm expecting 2 group certificates and i already recieved one but the other one has yet to come and they were both sent on the same day!
UNfkingBELIEVEABLE
SO I killed the cressida right, drove over 10kays with the needle on H, had the rattle of death going the whole time and also managed to cook the oil in it.
I topped up the oil/coolant today, turned the key and after a few lazy chugs, she fires up and settles to a reasonably good idle, given the previous abuse. I also drove it a further few kays with not a single problem (it hesitated slightly when moving off from a standstill on a steep hill).
I just can't fathom how it could take so much abuse and still run and drive like nothing happened. Fking 7M is damn near unbrakeable :)
UNfkingBELIEVEABLE
haha nice!
Ask Jeff from The Speed Lab how his rb20 is still running. Abuse and neglect to absolute maximum lol.
lol, it is slow when i have the missus in the car :D
she keeps me in line ha ha
I get my missus in the car and its slow.
I get her on the bike and she wants fast. :)
But too wet for the bike :P
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
