I've also heard that I should go for a non-Turbo first, especially since I'm driving an auto atm. Seems like a wise move IMO.
The 15k includes stamp duty, rego and insurance for a year (so about 12 or 13k for the car itself).
R34 non-turbos go for about $13k these days.
:devil: Just got to have a look at the girlfriends car, she's been complaining the last few days about overheating problems, turns out it's a stuffed head gasket. Trying to explain to her that you need to spend money on keeping a car going is like talking to a brick wall
Whos that Rad32 bloke? Had an awesome weekend in Blanchetown.
Ryan, me and Adrian were talking alot about RB30 bottom ends. What sort of difference would it make if i slapped one on my 25?
And Norman, if you think you'll be ok in a turbo, go for it. I went from an N/A auto S13 to my car, it all comes down to self control and, "easing into it".
all depends if its an early non turbo nonvvti rb25 head which came out in the late R32's or a later Turbo vvti rb25 head guys, im currently thinking about doing this for my R31. An oil gallery in the block has to be elongated to meet up with the vvti oil gallery in the head i believe, also a hole position is necessary to drill and tap a hole in the block for the idler pulley to incorporate the larger twin cam timing belt also. There is plenty of write ups about this on SAU and im sure Cubes has alot more information about it than i do...He'd be the one id ask if i needed information.
also, may take into consideration that most rb30's even tho they may be fine, would be worth either a standard spec rebuild with new rings etc..as a minimum requirement or either go all out and get a set of forgies etc....alot of work to just have a tired old motor wacked in.
Edited by Ryanrb25
You can run with the two lower tensioner locations. Just means a different cam belt.
Block off the oil galley for the vct in the rb25 head (not the block) and then drill/tap a feed for the vct or if you are running larger cams and don't wish to utilise the vct you drill the head to provide oil to the front cam bearing. Unsure exactly stockymcstock with his twincharged gt4088r rb30det worked out how to do it. :rofl:
If you run with the r32 rb25 head then its just bolts on and off you go. Its easy to lower the engine mounts ~13mm and should cost under $100. Boostworxs know what has to be done in this instance.
Once you go the 30 there's no going back. :D
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
