Grab some carby clean. They almost always gum up and cause idling issues.
Does the valve AAC valve need removal for cleaning?
If its idling too high there's another valve that may be the cause. IAC valve. The spring can dislodge and cause a constant 1000-1500rpm high idle.
Can the spring be relocated or would I need a newbie......also can a good hammering up the hills cause a dislodgement because its been like that ever since I went for a run with my mates Porsche & Maserati (gave it a bit of a hammering that day :blink: )
Yeah mine idles way too high. I'm guessing the AAC valve is the accessible the one near the fuel filter which can be cleaned whereas the IAC is probably the "cold air by-pass solenoid" which is against the sandwich plate under the centre throttle body which requires a plenum removal and which can't be cleaned (approx $220 new).
Also Cubes, have you got the full specs on your Tighe cams ie. IN & EX opening & closing times etc......I might look into them myself.
Can the spring be relocated or would I need a newbie......also can a good hammering up the hills cause a dislodgement because its been like that ever since I went for a run with my mates Porsche & Maserati (gave it a bit of a hammering that day tongue.gif )
I do have the cam sheet. All though your requirements will differ as you are blessed with solid followers.
Tighe did reduce the base circle some what however it doesn't appear to have created any problems.
http://www.skylinesaustralia.com/forums/in...t&id=173055
Unsure if a hammering can cause it to dislodge.. Possibly.
Grab a can of start ya bastard and check for vac leaks bfore you go to the trouble of pulling everything off.
If the spring flicks off you can hook it back on and secure it a little better.
The std gasket will most likely break so grab some ACL gasket paper (the hard yellow paper) as its the correct thickness.
how hard is it to un wire gtr injectors with resistor pack??
If you have used a 280zx/R30 style resistor pack its as simple as heading down to the local auto store picking up a Navara 8pin? from memory plug and connecting each pin to each other (bridge) via wires. Then remove the resistor pack and plug in the bridged plug.
Hey guys just a quick question, i have a massive coolant leak at the back of my engine im pretty sure its just the heater hose leaking, any ideas how hard this is to replace??? or any idea's what the leak could be from its right at the back of the enging just infront of the fire wall.
hmmm I seem to be having absolute shit luck this year. Swapped the Chaser for a stupidly worked JZX81 track car and a Cressida Grande. Over valued the cressy to the tune of like 3k, turns out the thing is fair f**ked. Lost my job so had to swap the 81 for the 32 I'm in now, didn't get anywhere near enough coin on top. Lost about 6 grand or so in those 2 transactions. Now the Cressy has blown a head gasket (even after being torqued to the proper specs - good old 7M :() and the 32 is missing 1x rear quarter.
Roll on 2009 :)
Anyone know how to untighten the screws on the front of the fuel rail? Or what i can put on there so its easier to get them out? In heaps tight and i need them out to replace the o rings. Start fixing some small problems before i start driving it again in 2 months.
hmmm I seem to be having absolute shit luck this year. Swapped the Chaser for a stupidly worked JZX81 track car and a Cressida Grande. Over valued the cressy to the tune of like 3k, turns out the thing is fair f**ked. Lost my job so had to swap the 81 for the 32 I'm in now, didn't get anywhere near enough coin on top. Lost about 6 grand or so in those 2 transactions. Now the Cressy has blown a head gasket (even after being torqued to the proper specs - good old 7M :( ) and the 32 is missing 1x rear quarter.
Roll on 2009 :)
Aren't Cressy's prone to warping head gaskets? My mates Cressy which had a 5M in it blew 2 head gaskets within 6 months :D
Yeah man cressys eat gaskets like they're goin out of fashion :) Its the head torque that is the problem. Mine has been re-torqued and still fked the gasket out (to it's credit, it did complete about 10kays worth of driving on the H with the bottom end rattling away before the head gasket went :))
I reckon I'm just gonna get a Falcon and stop spendin money modding cars for a while. The Falcon seems to be best suited to daily with occaisional towing duties, so I can still get the busted arse 32 out to the track to thrash, Crazy Max styles with munted rear quarter. At least if I hit the tyres on the entry to 1 it doesn't matter because that quarter is already f**ked :laughing-smiley-014:
what suspension matty?
kyb shocks, aurora springs.....7kg front, 5kg rear, standard size (but slotted) aus del front and rear brakes too................nothing special in pads, and they didnt fade or cook
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
