Grab some carby clean. They almost always gum up and cause idling issues.
Does the valve AAC valve need removal for cleaning?
If its idling too high there's another valve that may be the cause. IAC valve. The spring can dislodge and cause a constant 1000-1500rpm high idle.
Can the spring be relocated or would I need a newbie......also can a good hammering up the hills cause a dislodgement because its been like that ever since I went for a run with my mates Porsche & Maserati (gave it a bit of a hammering that day :blink: )
Yeah mine idles way too high. I'm guessing the AAC valve is the accessible the one near the fuel filter which can be cleaned whereas the IAC is probably the "cold air by-pass solenoid" which is against the sandwich plate under the centre throttle body which requires a plenum removal and which can't be cleaned (approx $220 new).
Also Cubes, have you got the full specs on your Tighe cams ie. IN & EX opening & closing times etc......I might look into them myself.
Can the spring be relocated or would I need a newbie......also can a good hammering up the hills cause a dislodgement because its been like that ever since I went for a run with my mates Porsche & Maserati (gave it a bit of a hammering that day tongue.gif )
I do have the cam sheet. All though your requirements will differ as you are blessed with solid followers.
Tighe did reduce the base circle some what however it doesn't appear to have created any problems.
http://www.skylinesaustralia.com/forums/in...t&id=173055
Unsure if a hammering can cause it to dislodge.. Possibly.
Grab a can of start ya bastard and check for vac leaks bfore you go to the trouble of pulling everything off.
If the spring flicks off you can hook it back on and secure it a little better.
The std gasket will most likely break so grab some ACL gasket paper (the hard yellow paper) as its the correct thickness.
how hard is it to un wire gtr injectors with resistor pack??
If you have used a 280zx/R30 style resistor pack its as simple as heading down to the local auto store picking up a Navara 8pin? from memory plug and connecting each pin to each other (bridge) via wires. Then remove the resistor pack and plug in the bridged plug.
Hey guys just a quick question, i have a massive coolant leak at the back of my engine im pretty sure its just the heater hose leaking, any ideas how hard this is to replace??? or any idea's what the leak could be from its right at the back of the enging just infront of the fire wall.
hmmm I seem to be having absolute shit luck this year. Swapped the Chaser for a stupidly worked JZX81 track car and a Cressida Grande. Over valued the cressy to the tune of like 3k, turns out the thing is fair f**ked. Lost my job so had to swap the 81 for the 32 I'm in now, didn't get anywhere near enough coin on top. Lost about 6 grand or so in those 2 transactions. Now the Cressy has blown a head gasket (even after being torqued to the proper specs - good old 7M :() and the 32 is missing 1x rear quarter.
Roll on 2009 :)
Anyone know how to untighten the screws on the front of the fuel rail? Or what i can put on there so its easier to get them out? In heaps tight and i need them out to replace the o rings. Start fixing some small problems before i start driving it again in 2 months.
hmmm I seem to be having absolute shit luck this year. Swapped the Chaser for a stupidly worked JZX81 track car and a Cressida Grande. Over valued the cressy to the tune of like 3k, turns out the thing is fair f**ked. Lost my job so had to swap the 81 for the 32 I'm in now, didn't get anywhere near enough coin on top. Lost about 6 grand or so in those 2 transactions. Now the Cressy has blown a head gasket (even after being torqued to the proper specs - good old 7M :( ) and the 32 is missing 1x rear quarter.
Roll on 2009 :)
Aren't Cressy's prone to warping head gaskets? My mates Cressy which had a 5M in it blew 2 head gaskets within 6 months :D
Yeah man cressys eat gaskets like they're goin out of fashion :) Its the head torque that is the problem. Mine has been re-torqued and still fked the gasket out (to it's credit, it did complete about 10kays worth of driving on the H with the bottom end rattling away before the head gasket went :))
I reckon I'm just gonna get a Falcon and stop spendin money modding cars for a while. The Falcon seems to be best suited to daily with occaisional towing duties, so I can still get the busted arse 32 out to the track to thrash, Crazy Max styles with munted rear quarter. At least if I hit the tyres on the entry to 1 it doesn't matter because that quarter is already f**ked :laughing-smiley-014:
what suspension matty?
kyb shocks, aurora springs.....7kg front, 5kg rear, standard size (but slotted) aus del front and rear brakes too................nothing special in pads, and they didnt fade or cook
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
